HONDA TEAM => Motorsporları => Konuyu başlatan: timucintt - Kasım 02, 2005, 02:50:42 ÖS
Benim çok hoşuma gitti 8)
Çok karizma bir S13 olmuş 8)
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/h.jpg)
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/a.jpg)
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/e.jpg)
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/l.jpg)
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/d.jpg)
Swap Sr20det rulezzz :D
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/v.jpg)
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/w.jpg)
(http://www.tunerzine.com/articles/2005/featuredcar/issue09/Pink240/images/p.jpg)
Bu arada bana göre S15 farları S13'e daha çok yakışıyor :cool:
Exterior
chargespeed full body kit chargespeed widebody chargespeed carbon vented s-15 hood charge speed s-15 front end conversion chargespeed carbon oem style hatch kouki s-13 tail light conversion s-15 oem headlights gtp carbon carnards
Wheels/Tires
maya stm wheels 19x9 +30H front w/25mm h&r wheel spacer 19x10.5 +29 rear w/10mm spacer nitto nt555 tires 23/35/19 front
275/30/19 rear
Brakes
Nissan z32 4 piston front calipers w.axis pads goodridge stainless brake lines brembo cross drilled rotors
Suspension
Tein flex full coilover set custom sagano revalve from tein upgraded spring rates -8 on front -10 on rear tein tie rods tein tie rod ends w/10mm shim tein tension rods tanabe upper rear camber amrs tanabe upper rear pillow link tanabe rear pillow toe rod billet subframe inserts tein EDFC dampening controller shakito upper front strut tower reinforcement
Interior
defi bf series oil pressure guage defi bf series water temp guage defi bf series egt guage defi bf series boost guage defi link guage controller sparco evo3 racing seats simpson 5 point harnesses platnuim series sparco passenger foot brace spw deep face racing wheel morroso racing quick release mazworks weld-in s-13 through-dash roll cage kit
Performance
greddy 18g turbo (polished) greddy sr20det intake manifold (polished) greddy oil catch can (polished) hks 555cc top feed injectors
hks top feed fuel rail topspeed stainless steel polished equal length turbo manifold topspeed turbo outlet housing enjuku racing test pipe apexi n1 cat back exhaust system greddy sr pulley kit top speed engine torque damper koyo aluminum radiator spal twin 12’ fan set greddy v-spec intercooler kit (polished) greddy z32 airnix filter kit z32 mass air sensor apexi safcII custom polished valve cover hks rocker arm stopper set hks oil cap greddyradiator cap aeromotive fuel pressure regulator aeromotive fuel filter earls fittings and hose ends custom stainless radiator overflow stinger sp800 drycell battery rear re-locationsr20det engine swap redtop
herşey çok iyidi diyeceğim ama o renk için diyemiyorum beyaz yada siyah çok deli gidiyor bu arabaya,yada bal köpüğü..
