Gönderen Konu: Honda Civic VTi Teknik Bilgiler  (Okunma sayısı 56685 defa)
  • Administrator
  • İleti: 4899
« : Aralık 28, 2006, 11:59:49 ÖS »
Honda Civic VTi HB
Bodywork / Karoser
Type: 4/5S HBK
Number of doors: 0
Dimensions / Boyutlar
Wheelbase: 2570 mm 101.18 in
Track front: 1475 mm 58.07 in
Track rear: 1465 mm 57.67 in
Length: 4080 mm 160.62 in
Width: 1695 mm 66.73 in
Kerb weight: 1080 kg 2380.98 lb
Fuel capacity: 45 l 11.88 US gal
Engine / Motor
Manufacturer: Honda
Type: S-4
DOHC
16 valves total
4 valves per cylinder
Main bearings: 5
Bore x stroke: 81.00mm × 77.40mm
Bore / stroke ratio: 1.05
Displacement: 1595 cc 97.33 cu in
Compression: 10.20:1
Fuel system: Ho PGM-Fi fuel inj.
Aspiration: Normal
Catalytic Converter: Y
Max. output: 162.2 PS (160.0 bhp) (119.3 kW)@7600 rpm
Max. torque: 150.0 Nm (111 lbft) (15.3 kgm)@7000 rpm
Coolant: Water
Specific output: 100.3 bhp/litre
Specific torque: 94.04 Nm/litre
Performance / Performans
0-60mph: 7.3 s
Quarter mile: 15.80s
Top speed: 212 km/h
Power to weight: 148.15 bhp/ton
Chassis / Sasi
Engine / Motor location: Front
Engine / Motor alignment: Transverse
Suspension front: I.W.CS.ARB.
Suspension rear: I.CS.W.ARB.
Brakes: VeDi/Di-S-ABS
Transmission: 5M
Drive: FWD
Top gear ratio: 0.88
Final drive ratio: 4.27
Honda Civic VTi Sedan
Bodywork / Karoser
Type: 4/5S SAL
Number of doors: 4
Wheelbase: 2620 mm 103.14 in
Length: 4405 mm 173.42 in
Kerb weight: 1118 kg 2464.76 lb
Engine / Motor
Manufacturer: Honda
Type: S-4
DOHC
16 valves total
Main bearings: 5
Aspiration: Normal
Coolant: Water
0-60mph: 7.7 s
Top speed: 216 km/h
Power to weight: 143.11 bhp/ton
Chassis / Sasi
Suspension rear: I.W.CS.ARB.
Transmission: 5M
Drive: FWD
« Son Düzenleme: Aralık 29, 2006, 12:02:38 ÖÖ Gönderen: VTEC »
timmaah
  • İleti: 275
Ynt: Honda Civic VTi Teknik Bilgiler
« Yanıtla #1 : Aralık 29, 2006, 12:24:29 ÖÖ »
teşekkürler çok yardımı oldu geçen bi konu açılmış sedan mı HB mi die sanırım bu o konuya da aydınlatıcı olur
SONE-R
  • İleti: 2064
« Yanıtla #2 : Aralık 29, 2006, 07:14:30 ÖÖ »
beygir güçleri yanlış kardeşim nerden aldıysan..
160 PS veya 158 HP veya 118 KW olacak doğrusu budur....
timmaah
  • İleti: 275
« Yanıtla #3 : Aralık 29, 2006, 09:53:10 ÖÖ »
Alıntı
vala bana beygirler doru gibi geldi ama HB nin kapı sayısı "0"mış onda bi yannışlık var sanursamm nerden binilio bu arabaya yahuuu  :dissiz
G60
« Yanıtla #4 : Aralık 29, 2006, 02:19:01 ÖS »
http://www.carfolio.com/ ;) .
serkan
« Yanıtla #5 : Aralık 29, 2006, 02:22:01 ÖS »
Bad Gateway
The proxy server received an invalid response from an upstream server.
G60
« Yanıtla #6 : Aralık 29, 2006, 02:27:17 ÖS »
Adres doğru.
Ancak sabahtan beri server'larında sorun var...
devil_civic
« Yanıtla #7 : Mart 11, 2007, 09:32:05 ÖÖ »
Alıntı
ahuahuahu camları açıp bnerler belki  ;D ;D ;D
mutunch
  • İleti: 900
« Yanıtla #8 : Mayıs 07, 2007, 05:07:15 ÖS »
Arkadaşım beygir güçleri doğru olmuş. Neden mi ? Çünkü orada litre başına alınan beygir güçleri verilmiş :) E bu durumda da doğru olmuş oluo litre başına 100 beygir.
« Son Düzenleme: Mayıs 07, 2007, 05:08:53 ÖS Gönderen: mutunch »
vtimania
  • İleti: 1116
« Yanıtla #9 : Mayıs 29, 2007, 02:24:18 ÖÖ »
vti torku 156
hifi
« Yanıtla #10 : Temmuz 19, 2007, 12:38:07 ÖÖ »
bencede litre başı verilen bilgiler dogru paylaşım için tşk
avci
  • İleti: 23
    • yusif1@free.fr
« Yanıtla #11 : Aralık 22, 2007, 11:24:04 ÖS »
b16a2 vti vtec motorlari 160 hp dir
selamlar
OzzWoLF
  • İleti: 363
« Yanıtla #12 : Eylül 03, 2008, 02:41:44 ÖÖ »
paylasım icin saol
turbovts2
  • İleti: 366
« Yanıtla #13 : Eylül 07, 2008, 11:35:46 ÖÖ »
7600 dd da 160 bg ve 7000 dd da 153 nm olması lazım. Paylaşım için teşekkürler.
cery
  • İleti: 76
« Yanıtla #14 : Eylül 09, 2009, 01:57:42 ÖS »
max hız 212 dio. çoğu vti bunun üstüne çıkıyor. kullanımdan dolayı mı ?? :D
MHMT-16
  • İleti: 208
« Yanıtla #15 : Eylül 09, 2009, 02:58:41 ÖS »
max hızı 212 olabılır...zaten kadran %100 dogru hızı vermıyor ki
« Son Düzenleme: Eylül 09, 2009, 02:59:43 ÖS Gönderen: MHMT-16 »
silence
  • İleti: 102
« Yanıtla #16 : Eylül 12, 2009, 12:17:40 ÖÖ »
arkadaslar bu vti ların pıyasası nıe bu kadar degısken ya temız bı vti ortalama ne kadardır??
poşetçay
« Yanıtla #17 : Ekim 05, 2009, 01:01:55 ÖS »
yok hepsi dolduruldundan dolayı
dede9009
  • İleti: 73
« Yanıtla #18 : Aralık 08, 2009, 04:09:30 ÖS »
caner_wcg
  • İleti: 7
« Yanıtla #19 : Nisan 17, 2010, 04:59:04 ÖS »
slm arkadaslar ben bısı merak edıyorum konuyu nereye acıcagımı bılmıyorum
stock crx stock vti  roll ve dragda hangısı ezer 2 aracta saglıklı yuruyen ve stock olarak
whiteaddict
  • İleti: 56
« Yanıtla #20 : Eylül 21, 2010, 09:48:19 ÖÖ »
Merhaba. Merak ettiğim bir şey var. 2001 model,otomatik vites 1.6 motor, 160 beygirlik bir sedan vti'ın şehiriçi-şehirdışı, benzinde ve lpg'de ne kadar yakacağını söyleyebilir misiniz? Teşekkürler.
web_luck
  • İleti: 439
« Yanıtla #21 : Eylül 21, 2010, 09:53:48 ÖÖ »
2001 1.6 otomatik 160 hp vti yoktur 110 hpdir aracınız. LPG ile yaklaşık aracınız 160 krş felan yakar
whiteaddict
  • İleti: 56
« Yanıtla #22 : Eylül 21, 2010, 11:55:28 ÖÖ »
Teşekkürler web_luck.
burak_sahin3455
  • İleti: 10
« Yanıtla #23 : Ekim 13, 2010, 08:49:04 ÖÖ »
Honda Civic Vtiler 160 hp 118 KW b16a2 doch wtech motorludur .+5500 den sonra otur sesi dinle:)
burak_sahin3455
  • İleti: 10
« Yanıtla #24 : Ekim 13, 2010, 08:51:39 ÖÖ »
Crx kalkışta bir boy koyabilir çünkü vti den daha hafiftir ama roll de vti alır
