K20
K20AThe 1,998 cc (1.998 L; 121.9 cu in) K20 engines have 86 mm (3.4 in) bore and 86 mm (3.4 in) stroke. The 2,157 cc (2.157 L; 131.6 cu in) version has 87.0 mm (3.43 in) bore & 90.7 mm (3.57 in) stroke.
Applications:
2,157 cc (2.157 L; 131.6 cu in), 260 PS (190 kW; 260 hp) @8250, 237 N·m (175 lb·ft) @6750:
Honda Civic Mugen RR Advanced Concept
1,998 cc (1.998 L; 121.9 cu in), 240 PS (180 kW; 240 hp) @8400, 216 N·m (159 lb·ft) @7000:
Honda Civic Mugen(Honda ABA-FD2)
1,998 cc (1.998 L; 121.9 cu in), 225 PS (165 kW; 222 hp) @8000, 215 N·m (159 lb·ft) @6100:
2007- JDM Honda Civic Type-R (FD2)
1,998 cc (1.998 L; 121.9 cu in), 215 PS (158 kW; 212 hp) @8000, 200 N·m (150 lb·ft) @7000:
2001-2006 JDM Honda Civic Type-R (EP3)
1,998 cc (1.998 L; 121.9 cu in), 220 PS (160 kW; 220 hp) @8000, 206 N·m (152 lb·ft) @7000:
2001-2007 JDM Honda Integra Type-R (DC5)
1,998 cc (1.998 L; 121.9 cu in), 185 PS (136 kW; 182 hp) @1000, 196 N·m (145 lb·ft) @2000:
2002-2004 Honda Integra Type-S (DC5)
1,998 cc (1.998 L; 121.9 cu in), 210 PS (150 kW; 210 hp) @7800, 191 N·m (141 lb·ft) @4000:
2005-2006 Honda Integra Type-S (DC5)
1,998 cc (1.998 L; 121.9 cu in), 220 PS (160 kW; 220 hp) @8000, 206 N·m (152 lb·ft) @6000:
2003-2007 JDM Honda Accord Euro-R CL7
K20A2Found in:
2002-2004 RSX Type-S (USDM)
2002-2004 Honda Integra Type R (Australia)
2002-2005 Honda Civic Type R (EP3, European)
Displacement: 1,998 cc (121.9 cu in)
Compression: 11.0:1
Power: 200hp @ 7400 rpm
Torque: 142 ft·lbf (196N·m) @ 5600 rpm
Redline: 7900 rpm
Rev limit: 8100 rpm (USDM RSX-S, U.K Civic-R )
i-VTEC engagement: 5800 rpm
K20A3Found In
2002-2005 Honda Civic Si (EP3)
2002-2005 Honda Civic SiR (EP3)(Canadian version of US Civic Si)
2002-2006 Acura RSX
Compression: 9.5:1
Power: 160hp(120 kW) @ 6500 rpm(SAE net J1349 Rev 8/04)
Torque: 132 lb·ft (179 N·m)* (191 N·m) @ 5000 rpm(SAE net J1349 Rev 8/04)
Redline: 6800 rpm
i-VTEC Engagement Window: 2200 rpm
K20A4Found in:
2003-2005 Honda Accord (UC1)
2006-2008 Honda Accord (UC3)
2001-2007 Honda CR-V (RD5)
2000-2003 Honda Stream (RN1)
2004-2007 Honda Stream (RN3)
K20A6Found in:
2003-2005 Honda Accord (European)
Compression 9.8:1
Bore / Stroke 86 mm x 86 mm
190nm Torque @ 4500rpm
160hp @ 6000rpm
Similar to the K20A3.
K20Z1Found in:
2005-06 Acura RSX Type-S
2005-06 Honda Integra Type-S (Australia)
Compression: 11:0:1
Power: 210 hp (154 kW) @ 7800 rpm
Torque: 143 ft·lb (194 Nm) @ 7000 rpm
Redline: 8300 rpm
i-VTEC Engagement Window:5800 rpm
K20Z2Found in:
2006- Acura CSX (Canada)
Compression: 9.6:1
Power: 155 hp (114 kW) @ 6000 rpm (SAE net J1349 Rev 8/04)
Torque: 139 ft·lbf (188 N·m) @ 4500 rpm
Redline: 6800 rpm
2006- Honda Civic (JDM)
Compression: 9.6:1
Redline: 6800 rpm
2006- Honda Accord(Europe)
Displacement: 1998 cc
Compression: 9.6:1
Redline: 6800 rpm
K20Z3This inline-4 cylinder internal combustion engine is found in the US market Honda Civic Si (2006+) & Canadian market Acura CSX Type-S, as well as the Honda Accord CL-9 Euro R model. It has an aluminum block with an aluminum head, and a bore and stroke of 86 mm x 86 mm, resulting in a 1,998 cc (121.9 cu in) displacement.
Found in:
2006-2010 Honda Civic Si (FG2 - Coupe & FA5 - Sedan), 2007 Acura CSX Type-S
Displacement : 1,998 cc (121.9 cu in)
Compression : 11:1
Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 139 ft·lbf (189 N·m) @ 6200 rpm (sae NET Rev 8/04)
Redline: 8000 rpm
Fuel Cutoff: 8300 rpm
