MULTIMEDIA => Fotoğraflar => Konuyu başlatan: @kın dohc - Temmuz 04, 2007, 09:35:24 ÖS
(http://img408.imageshack.us/img408/874/61761446iw6.jpg) (http://imageshack.us)
(http://img240.imageshack.us/img240/8342/16955452vg6.jpg) (http://imageshack.us)
(http://img240.imageshack.us/img240/9789/img6832qr3.jpg) (http://imageshack.us)
(http://img509.imageshack.us/img509/5681/img6866wg7.jpg) (http://imageshack.us)
(http://img509.imageshack.us/img509/5108/img6880hm1.jpg) (http://imageshack.us)
(http://img408.imageshack.us/img408/2054/img6883vo4.jpg) (http://imageshack.us)
(http://img240.imageshack.us/img240/6378/img6885tu0.jpg) (http://imageshack.us)
Exterior:
Version Select body kit, JDM S14 grill, turn signals; Rotora Carbon GT wing, Sparco hood pins
Engine:
S13 SR20DET swap, Wiseco 8.5:1 compression pistons, ESP Eagle I-Beam rods, HKS 272 step-2 cams, cam gears, valve springs, rocker arm stoppers; A’PEXi metal head gasket, ARP head studs, GReddy oil pan, T67-25G turbo, Evolution TR2 exhaust, Type-R intercooler, Type-R blow off valve, intake manifold, accessory pulley, oil cap, oil relocation kit, catch tank, radiator cap; Tomei fuel rail adapter, 70mm throttle kit; SX fuel pressure regulator, SARD 850cc injectors, Slick Motorsports twin Walbro fuel pump kit, 90mm intake, intercooler pipes; HKS air filter, Koyo aluminum radiator, Flex-a-Lite dual electric fans
Engine Management:
AEM EMS, E-Boost Boost Control
Drivetrain:
Mazworx 300zx transmission upgrade kit, Z32 300ZX transmission, Exedy x2 Plate Clutch, Nissan R200 Viscous LSD
Suspension/Brakes/Wheels:
TEIN FLEX Master coilover suspension, Torsion rods, steering rods; Tanabe rear drift control arms, front lower brace; Megan rear sub-frame brace, Nismo sub-frame bushing kit, Energy Suspension bushing kit, Cusco Type-OS front upper strut bar, 300ZX front calipers, I-Rotor slotted and cross drilled front rotors, Brembo rear rotors, Hawk HPS brake pads; 17x9 5Zigen FN01R-C wheels with 245/45/17 Nitto NT-01 tires (front), 15x10 5Zigen FN01R-C wheels with 275/40/17 Nitto NT-01 tires (rear)
Interior:
Nismo shift knob, GReddy 52mm EGT, Oil Pressure, Fuel Pressure gauges, Sparco steering wheel
Yahu bu araçlar hiç mi yaşlanmaz. Hiç mi yorulmaz. Hep böyle nası mükemmel kalabiliyolar.
Ben oynamicam en sonunda ya.
Tatlı Olmuş Ama s14 lerin önünü beğenmiyorum s14a ya yapılsaymış ii ollurmuş...
her yanından karakter akıyor makinanın...
Ahh Japonya ahh...
jant lastıkler güzel olmuş ..
paylaşım için teşekkurler ..
fenaa :lovee :lovee
Engine:
Engine Management:
Drivetrain:
S13 SR20DET swap Nedir Ya ? s13 lerde ca18dett Motor Vardı. S14 Kasada sr20det Motor Var. Of Bu Motor Kadar Oynamaya Müsait Bir Motor Görmedim Ben. Motora Su Sıçrasa +hp Veriyor Anlamadım Gitti :D
tek kelimeyle M Ü K E M M E L....
paylaşım için teşekkürler
