HONDA => Motor, Modifiye & Do it yourself - Teknik bilgiler => Konuyu başlatan: TEAMHONDATURKEY - Haziran 08, 2006, 10:57:45 ÖÖ
Başlık: S.W.A.P ***
Gönderen: TEAMHONDATURKEY - Haziran 08, 2006, 10:57:45 ÖÖ
      94-96 (GSR) B18C Engine
      Swap: $3085.00
      -Only long blocks in stock currently $1850.00 & Completes w/ LSD $3300.00
      • 1800cc (1.8L) DOHC Vtec engine.
      • 180hp/126trq, 10.6 compression ratio. (U.S. version has 170hp and 10.1
      cr.)
      • Hydro tranny type.
      • P72 OBD-1 or OBD-2 ECU equipped.
      • Inquire within for LSD equipped trans. (not all trans are LSD equipped).
      • U.S. version of this engine is available. Also, specify which year type
      you need (OBD-1/2).
      97-00 (GSR) B18C Engine
      Swap: $3600.00
      -Out of stock
      • 1800cc (1.8L)DOHC Vtec engine.
      • 180hp / 126trq / 10.6 compression ratio. (U.S. version has 170hp and
      10.1 cr.) • Hydro tranny type.
      • U.S. version of this engine is available.. Also, specify which year type
      you need (OBD-1/2).
      94-98 Integra Type- R Engine
      Swap: $4800.00
      -Out of stock
      • 200hp / 18.5Nm trq / 11.1 cr., DOHC Vtec (U.S. version is 195hp/10.6
      cr.)
      • Integra-R P73 OBD-2 ECU type.
      • We have access to U.S. version Integra Type-R engine's as well.
      94-98 Civic R (B16B) Engines
      Swap: $4600.00
      -Out of stock
      • 185 hp / 118 trq / 10.8 cr., DOHC Vtec Engine.
      • Civic-R PCT OBD-2 ECU type.
      92-95 Prelude H22A Engine
      Swap: $2250.00
      • 2200cc (2.2L) DOHC Vtec Engine
      • 200hp / 161trq / 10.6:1 cr.
      • Hydraulic tranny type
      • Inquire within if you desire the U.S. version of the this engine.
      96-00 Prelude H22A Engine
      Swap: $3100.00
      -Out of stock
      • 2200cc(2.2L) DOHC Vtec.
      • Inquire within if you prefer the U.S. version of the this engine.
      Enjoy the Speed!*!
http://www.jaydm.com/jdm.htm
Başlık: Ynt: S.W.A.P ***
Gönderen: can - Haziran 08, 2006, 11:02:45 ÖÖ
buraya gelirken bu fiyatlar kaç katına çıkıo onları da yassak ii olcaktı :)
Gönderen: Emes - Haziran 08, 2006, 04:01:36 ÖS
Arkadaşlar
adresinde motoru alıyorum mesela buy tıkladım paypal acılıyor ve shipping sıfır bu nasıl oluyor
Subtotal: $4,050.00 USD
Shipping & Handling: $0.00 USD
yazıyor daha ılerı gıtmedım sayfada
 (http://www.japangeneraljdmmotors.com/honda.htm[/url)
Gönderen: WildCat_H22A - Haziran 08, 2006, 05:33:38 ÖS
ben bu fiyatların çok çok altında 1 yıl sınırsız km garantili olan firmalaraı buldum yakında yazıcam B16B arlıcam inş.
Gönderen: Emes - Haziran 08, 2006, 07:41:56 ÖS
Hocam bu iş nasıl oluyor ?
TR de mi yoksa gene yurtdışımı
1 Haftadır kafayı peynir ekmekle yiyorum söyle hocam merakta bırakma  :roll:
Gönderen: WildCat_H22A - Haziran 09, 2006, 07:44:51 ÖS
Japonyadan arkadaşlar... USA daki JDM motor firmalarının hepsi kazıkçı. Bu japon firma garantili usadakiler doğru dürüst garati vermiyor. fakat japonyadan gelen motora modifiye yapmak yasak yoksa garanti dışı. motoru sağlayan firma HONDA Motor Co. nun denetimi altında ve birebir en ufak parçadan en buyuğune kadar eskiyen tum parcalar değişerek satılıyor. 10K ila 60K km arasında ortalama 25-30 binde motorlar. Çoklu motor alımlarında iskonto var. USA daki profesyonel dragçılar swap işlerinde görmüş geçirmiş olayı aşmış adamlar kendilerini usa daki firmlara kazıklatmayıp direk japonyadan alıyorlar. Bu videolarını izlediğimiz bir sürü amerikalı pro dragçıyla görüştüm ve yalvar yakar birkaç adrese ulaştım. yakında ciddi olarak düşünenlere sunucam bu olayı. Çoğu arkadaşımız serviste rektifiye ettirme parasına VTEC e biniceek inşallah.   az kaldı coming soon. Ben ya B16B yada B18C5 düşünüyorum prelude alırsam H22A bile buldum. ne arıyorsanız var.
Gönderen: Emes - Haziran 09, 2006, 08:24:24 ÖS
Merakla bekliyoruz adresi
Gönderen: SLMKYNR - Eylül 09, 2008, 04:28:49 ÖS
Burası yalan olmuş galiba.
Var mı aksini idda edecek?
Gönderen: OzzWoLF - Eylül 10, 2008, 09:57:52 ÖÖ
türkiye pazarındada var ama kaliteli degil
ABD de var ama kazıkcı
Japondada var ama taa ordan buraya gelene kadar parcalar curur.
Offf offf
Gönderen: integratypeR - Eylül 10, 2008, 10:21:15 ÖÖ
 swap ne demek türkçe
Gönderen: muRatpasa - Eylül 10, 2008, 12:16:32 ÖS
bende de 91 civic var arkadaşlar, bu konuda yapılabilecekler hakkında bilgilendirirseniz sevinirim, ben motor işine girmeyi düşünmüyordum açıkçası.
ama bu tabloda bişeyler düşünülebilir...
Gönderen: yassi - Eylül 10, 2008, 12:36:15 ÖS
swap kelimesi tuning camiasında motor modifiyesinde kullanılır. Yani honda motoru diyelim B16A iken B20A,  olarak yükseltiğinde denilir diye biliyorum...
Gönderen: muRatpasa - Eylül 10, 2008, 12:39:31 ÖS
swap : değiştirmek
kelimenin anlamı
Gönderen: -cenk- - Eylül 10, 2008, 12:56:07 ÖS
ya bu jdm motorlar gerçekten süper ancak oradaki fiyatlarla süper.buraya gelirken bizim başımıza gelecekleri ufakça açıklayayım.
1-shipping. (kilo ve boyuta göre getirecek olan konteyner firmasının insafına kalmış)
2-gümrük. (işte bu türk insanının yıllardır saçını beyazlatan şey.Hak bile nekadar tutar onun vergisi)
3-ruhsat işletim. ( cebinizi çok sarsmasada aynı binada 3 yukarı 8 aşşağı yaparak odadan odaya girip çıkacağınız küçük bir maratonun başlangıcı.madalyası motor kodunun ruhsata yazılması)
4-iyi usta ( hadi bunu bulmak kolay ancak para ödemeden kimse iş yapmaz doğal olarak)
 yani arkadaşlar demem oki bu zevklerle yanlış yerdemi yaşıyoruz yoksa bu dayatmalarmı yanlış bilemiyorum ama saçma sapan kurallar yüzünden insanların ihtiyaçlarını bile karşılayamıyo olmaları acı.
Gönderen: integratypeR - Eylül 10, 2008, 12:59:51 ÖS
:) sağolun bana çok komik geliyor böle yabancı terimler bildiğimiz şeyler fakat kelime yabancı olunca :)
