HONDA TEAM => Motorsporları => Konuyu başlatan: STP - Kasım 22, 2005, 03:33:02 ÖS
Başlık: the FASTest CİVİC in the WORLD
Gönderen: STP - Kasım 22, 2005, 03:33:02 ÖS
(http://www.aempower.com/race/car/1_6.jpg)
Race Proven Performance. At AEM this isn't a gimmick, it's a fact that is proven by our own race team, and some of the country's best racing teams. If our products are reliable on our 1,500 horsepower racecar, we are confident that they will perform under the hood of your vehicle.
twinturbocharged NSX V6 engine 1500+ horsepower
(http://www.aempower.com/race/car/1_3.jpg)
ENGINE
ENGINE: 3.2-Liter NSX V6
COMPRESSION RATIO: 11.5:1 :eek:
CRANKSHAFT: Custom Billet
TRANSMISSION: Lenco Five-Speed
RODS: GRP Aluminum
PISTONS: Wiseco Forged
VALVETRAIN: Ferrea
CAMSHAFTS: Crane Cams
ROCKER ARMS: AEM Custom
CAM GEARS: AEM
INTAKE MANIFOLD: Hogan’s Racing Manifolds
INTAKE SYSTEM: AEM Custom
ENGINE MANAGEMENT: AEM EMS + AEM Peak & Hold Injector Driver Modules
ENGINE DATA AQ: AEM EMS
AIR/FUEL CONTROLLER: AEM Dual-Channel Wideband UEGO
FUEL PUMP: Waterman Racing Components
INJECTORS: RC Engineering 1600cc (12)
DRY SUMP SYSTEM: Bill Dailey Engineering
THROTTLE BODY: 80mm
TURBOCHARGERS: Twin Garrett Ball Bearing Turbochargers
WASTEGATES: Twin Tial
EXHAUST: Bob Marker Fabrication 321 Stainless Steel
IGNITION: AEM C2DI
RADIATOR: Fluidyne
CLUTCH: ACT XTM Drag Clutches
BELL HOUSING: Trick Titanium
ENGINE MACHINE WORK: Cosworth
legal record of 0-402m:6.108
ıllegal record of 0-402m:5.850
Gönderen: HONDA - Kasım 22, 2005, 03:39:00 ÖS
Alıntı
 :eek:  Olağanüstü olmuş. Yürürken (uçarken) görmek isterdim.
Gönderen: hakangunduz - Kasım 22, 2005, 03:47:07 ÖS
motor fena ya ik tane K20 gördüm orda ama :P
Gönderen: ImportRacer - Kasım 22, 2005, 03:55:40 ÖS
1500hp  :shock:
Gönderen: STP - Kasım 22, 2005, 04:01:35 ÖS
aldıgım duyumlara gore suan 2000 hp yı gecmısler.. dıkkatınızı cekmek ıstedıgım bır konu turbo aractakı sıkıstırma oranı  11.5:1  bız atmosferık besleme yaparken max 12 lerde dolasıyoruz overboost yaparken 9 dan yukarı basamıyoruz ama adamlar oyle bır gomlek kullanmıslarkı 11.5 e basıyolar.sıze soyle soylıyım arkadaslar bız Tb yı overboost dusunurken cok agresıf olsun dıye 9.0:1 e basalım dıyorduk artık sız dusunun... 11.5:1 :eek:
Gönderen: ImportRacer - Kasım 22, 2005, 04:15:30 ÖS
... :eek:  :eek:  :eek:
Gönderen: memopad - Kasım 22, 2005, 04:56:07 ÖS
korkunç bir güç... :shock:  :shock:  :shock:
Gönderen: timucintt - Kasım 23, 2005, 02:02:20 ÖÖ
Çok güzelmiş  :D
Gönderen: Güven - Kasım 23, 2005, 09:19:13 ÖÖ
:shock: Gözlerim yuvasından fırlayacak gibi
Gönderen: ALG - Aralık 17, 2005, 03:55:01 ÖÖ
bu ne boyle yaa..
Gönderen: can - Aralık 17, 2005, 04:28:07 ÖÖ
ağbi kaç basıyo bu :D
Gönderen: mrs.dd1777 - Aralık 17, 2005, 11:20:12 ÖS
bu nasıl olabiliyo yaa..   :shock:  :shock:
Başlık: DEVİL CIVIC
Gönderen: devil_civic - Aralık 18, 2005, 04:48:07 ÖS
abi makina MANYAK yaa :shock:  :shock:  :shock:  :shock:
Gönderen: tolgabin - Şubat 11, 2006, 03:41:46 ÖÖ
bunun civiclik falan hali kalmamış bu acayip bişey olmuş yaw
Başlık: Ynt: the FASTest CİVİC in the WORLD
Gönderen: can - Mayıs 04, 2006, 03:00:55 ÖÖ
2 tane k diil o sanırım C serisi nsx motoru :)
Gönderen: DuDuM - Mayıs 05, 2006, 03:33:49 ÖS
bu gerçek mi  :o
Gönderen: C.E.M - Mayıs 05, 2006, 03:57:16 ÖS
tamamen ;D
Gönderen: speedy_gonzales - Mayıs 08, 2006, 11:25:31 ÖÖ
Maşşallahhhh... :o :o :o
Gönderen: VTEC - Mayıs 13, 2006, 08:10:03 ÖÖ
Aem yapmış gene yapacağını ;)
