HONDA TEAM => Sohbet / Off Topic => Konuyu başlatan: hakangunduz - Kasım 17, 2005, 03:43:14 ÖS
Başlık: 2006 BUGATTI VEYRON - HENESSY VIPER VENOM
Gönderen: hakangunduz - Kasım 17, 2005, 03:43:14 ÖS
engine Quad Turbo W16
valvetrain DOHC 4 Valves / Cyl w/VVT
displacement 7993 cc / 487.8 cu in
bore 86 mm / 3.39 in
stroke 86 mm / 3.39 in
BUGATTI SPECS
compression 9.0:1
power 646.5 kw / 987 bhp @ 6000 rpm
hp per litre 125.25 bhp per litre
bhp/weight
torque 1250 nm / 922.0 ft lbs @ 2200-5500 rpm
drive wheels Mid Engine / 4WD
front wheels F 52 x 23.5 cm / 20.5 x 9.3 in
rear wheels R 54 x 32.5 cm / 21.3 x 12.8 in
front tire size PAX 245/690R520
rear tire size PAX335/710R540
weight 1888 kg / 4162 lbs
transmission 7-Speed DSG
top speed 407.2 kph / 253 mph
0 - 60 mph 2.5 seconds
VIPER SPECS
engine Venom 1000 90 Degree V10
position FFront Longitudinal
aspiration Twin Garret Turbos
valvetrain Pushrod Activated OHV, 2 Valves per Cyl
fuel feed Electronic Sequential Injection
displacement 8554 cc / 522 cu in
compression 9.0:1
power 745.7 kw / 1000 bhp @ Not Available rpm
hp per litre 116.9 bhp per litre
bhp/weight 291.55 bhp per weight
drive wheels RWD
body / frame SMC & RIm Panels over Tubular Steel Spaceframe
front brakes Brembro Vented Discs
f brake size 356 mm / 14.0 in
rear brakes Brembro Vented Discs
r brake size 356 mm / 14.0 in
front tire size P265/35YR-18
rear tire size P335/30YR-20
f suspension SRT10 KW Adjustable Suspension System
r suspension SRT10 KW Adjustable Suspension System
weight 1556 kg / 3430 lbs
transmission 6-Speed Manual
0 - 60 mph 2.25 seconds
0 - 1/4 mile 9.75 seconds
Gönderen: HONDA - Kasım 17, 2005, 03:45:42 ÖS
Bu ne şimdi?
Gönderen: hakangunduz - Kasım 17, 2005, 03:47:12 ÖS
silebilirsin
Gönderen: HONDA - Kasım 17, 2005, 03:54:26 ÖS
Herkes açsın o zaman ben sileyim olurmu?
Gönderen: hakangunduz - Kasım 17, 2005, 04:18:45 ÖS
:D
Gönderen: hakangunduz - Kasım 17, 2005, 04:27:28 ÖS
avatarımdaki yeşil araba seninmi yoksa Ömercim kihkihkih :cool:
