MULTIMEDIA => Fotoğraflar => Konuyu başlatan: @kın dohc - Kasım 04, 2007, 09:52:50 ÖS
Sessizliği bozayım dedim yorumları eksik etmeyelim :girls
(http://img161.imageshack.us/img161/5244/66569914ye5.jpg) (http://imageshack.us)
(http://img251.imageshack.us/img251/1637/22176775dg6.jpg) (http://imageshack.us)
(http://img251.imageshack.us/img251/6214/aleg1zj2.jpg) (http://imageshack.us)
(http://img141.imageshack.us/img141/9258/aleg4ay0.jpg) (http://imageshack.us)
(http://img251.imageshack.us/img251/3915/aleg7ft6.jpg) (http://imageshack.us)
(http://img229.imageshack.us/img229/3298/aleg11an7.jpg) (http://imageshack.us)
(http://img150.imageshack.us/img150/6783/aleg19pk8.jpg) (http://imageshack.us)
(http://img141.imageshack.us/img141/519/aleg22xw5.jpg) (http://imageshack.us)
(http://img108.imageshack.us/img108/7418/aleg39rx9.jpg) (http://imageshack.us)
Engine & Transmission:
H22 ENGINE & TRANNY, CROWER STAGE 3 CAMS (316 DURATION), FERREA VALVETRAIN, MAHLE 11.5/1 PISTONS, CROWER MAX LIGHT RODS, POLISHED AND BALANCED HONDA CRANK, HASPORT ENGINE MOUNTS, UNORTHODOX RACING CRANK PULLEY, STR THROTTLE BODY (70MM), CARBON FIBER INTAKE TUBE, BPI VELOCITY STACK [TRACK], AEM FUEL RAIL, EARLS PRO LIGHT FUEL HOSE AND FITTINGS, EARLS 35 MICRON FUEL FILTER, B&M FUEL PRESSURE REGULATOR, RC 440CC INJECTORS, NGK SPARK PLUG WIRES, MSD BLASTER COIL, FIDANZA CAM GEARS, MOTORVATIONS CAM SEAL, UNORTHODOX OIL CAP, HYTECH TRI-Y CUSTOM HEADER (2.5IN COLLECTOR), K-TELLER EXHAUST PIPING WITH MAGNAFLOW RESONATOR, AND ES OVAL MUFFLER (ALL 2.5IN), CUSCO OIL CATCH CAN, FLUIDYNE RADIATOR WITH FAL FAN, FIDANZA FLYWHEEL, ACT XTREME PRESSURE PLATE WITH 6-PUCK UNSPRUNG RACE DISC, HONDATA S200 (TUNED BY JIM HELBING AT MOTORVATIONS), CHASEBAYS WIRE TUCK
Exterior:
PAINT BY JONATHAN GOOLSBY AT GOOLSBY CUSTOM AND COLLISION, SEIBON CARBON FIBER HOOD, BACKYARD SPECIAL CARBON FIBER FRONT SPOILER, VISION CARBON FIBER MIRRORS, CARBON FIBER DUCKBILL, TYC HEADLIGHTS, MCCULLOUGH HID’S (10,000K), AMBER CORNERS, HONDA OEM FOG LIGHTS, ‘99 CIVIC SIDE SKIRTS, VISION HOOD DAMPER’S
Interior:
USDM RECARO SRD’S, MOMO TUNER STEERING WHEEL, NRG SHORT HUB, NRG QUICK RELEASE, “JDM” SI-R GAUGE CLUSTER, “JDM” ITR SHIFT BOOT, SPOON SPORTS SHIFT KNOB, MUGEN SPORT PEDALS, HONDA OPTIONAL AUDIO CONSOLE
Wheels, Suspension, and Brakes:
ENKEI RPF1 16X7, NITTO NEO GEN’S (205-45-16), INTEGRA GSR FRONT AND REAR DISK BRAKES, BREMBO SLOTTED ROTORS, RUSSELL STAINLESS STEEL BRAKE LINES, AXXIS METAL MASTER BRAKE PADS, SKUNK 2 EXTENDED FRONT AND REAR STUDS, KYOKUGEN LUG NUTS, SPOON SPORTS REAR UPPER AND LOWER TIE BARS, TENZO R FRONT UPPER STRUT BAR, OMNIPOWER FULL BODIED COILOVERS, OMNIPOWER REAR LOWER CONTROL ARMS, SKUNK 2 REAR UPPER CAMBER KIT
cook temız bı sı ılk defa boylesını gordum..
paylasım tesekk..
valla 10 numara mis mis...
Cok guzel ama bence onfarlar olmamıs
Egzoz daha ii bişyler olabilirdi ama >%Sakin >=ok
>=ok
sade ve şık bı SI.. :lovee
paylaşımın için saol.. >=ok
>=ok
ÇOK GÜZELL BEEHH....
süpeeeeeeeeeeeeeeeeeeeeeer harika olmuş
jjjdddmmm >=ok
bomba bombaa :)
h22 satage 3 atmosferik , ne cırlar bu yaaaa,,,, hayalimdi böyle bi atmosferik yapmak , süper olmuşş >=ok
bunun sahibi kesin türkdür baksana yanda NO PARKİNG yazıoo >%6rol
