Daniel Gabriel
« : Aralık 09, 2005, 01:57:09 ÖS » |
The GENERATIONS 1st gen. 1979 - 1982 2nd gen.1983 - 1987 3rd gen. 1988 - 1991 4th gen. 1992 - 1996 5th gen. 1997 - 2001
1ST GENERATION Year '79 - '82
ENGINE 1979 4-1751cc 1.8L SOHC EK1 3-bbl 1980 4-1751cc 1800 EK1 1981 4-1751cc 1.8L SOHC EK1 3-bbl 1982 4-1751cc 1800 EK1 Horsepower@rpm (SAE net)MT / AT.....................72@4500 / 68@4500 Torque (lb.ft.) MT / AT........................................... 94@3000 / 94@2500 Compression Ratio............................................. ..... 8.0:1 Valve Train............................................. .................SOHC 12-Valve Fuel Induction System............................................ ..Venturi Carburetor Ignition.......................................... ...........................System Electronic
DRIVE TRAIN Type.............................................. .......................... Front-Wheel Drive Manual Transmission...................................... .......... 5 Speed Automatic Transmission...................................... ...... 3 Speed Final Drive Ratio (MT / AT) .....................................3.875 / 4.214
BODY/SUSPENSION/CHASSIS Body Type.............................................. ................. Unit Body Suspension (front/rear)............................................. . 4-Wheel Independent w/ MacPherson Strut Steering Type.............................................. ............. Power-Assisted Rack and Pinion Steering Wheel Turns, Lock-to-Lock....................... 3.26 Turning Diameter, Curb-to-Curb (ft.)........................ 33.5 Brakes............................................ ......................... Power-Assisted Front Disc / Rear Drum Wheels............................................ ........................ 13" Steel Tires............................................. ........................... 175 / 70 SR 13
CAPACITIES Engine Oil with Filter (qt.) 4.2 Fuel (gal.) 13.2 Cooling System (qt.) 6.4
2ND GENERATION Year '83 - '87
ENGINE MODEL, S, SI Type Inline 4 Displacement...................................... ... (S)1829 cc (SI)1955 cc Horsepower@rpm (SAE net)................ (S)100@5500 (SI)110@5500 Torque (lb.ft.)........................................ (S)107@4000 (SI)114@4500 Valve Train............................................ SOHC 12-Valve Fuel Induction System............................ (S)Venturi Carburetor (SI)PGM-FI Ignition System....................................... Electronic
DRIVE TRAIN Type.............................................. ........ Front-Wheel Drive Manual Transmission.............................. 5-Speed Automatic Transmission.......................... 4-Speed w/Lock-Up
BODY/SUSPENSION/CHASSIS Body Type Unit Body Suspension (front/rear) Upper Wishbone, Lower Control Arm/MacPherson Strut Steering Type Variable-Assist Power Rack-and-Pinion Turning Diameter, Curb-to-Curb (ft.) 34.1 Brakes 4-Wheel Power-Assisted Disc Wheels............................(S) Steel (SI)Alloy
CAPACITIES Fuel (gal.) 15.8
3RD GENERATION Year '88 - '91
Model 2.0 S...................... '88-'90 2.0 Si..................... '88-'91 Si ...........................'90-'91
ENGINE 2.0S Type.............................................. .....Aluminum-alloy in-line 4 Displacement...................................... 1958 cc Horsepower@rpm (SAE net).............105@5800 Torque (lb.ft.).....................................111@4 000 Compression Ratio............................. 9.1:1 Valve Train........................................ SOHC, 12-Valve Fuel Induction System .......................Dual Sidedraft Constant Velocity Ignition System...................................Electroni c 2.0 Si Type .................................................A luminum-alloy in-line 4 Displacement.....................................1 958 cc Horsepower@rpm (SAE net)............135@6200 Torque (lb.ft.)....................................Torque (lb.ft.) Compression Ratio............................ 9.0:1 Valve Train....................................... DOHC, 16-Valve Fuel Induction System....................... PGM-FI Ignition System.................................. Electronic Si Type.............................................. ...Aluminum-alloy in-line 4 Displacement.....................................2 056 cc Horsepower@rpm (SAE net)............140@5800 Torque (lb.ft.)....................................135@50 00 Compression Ratio.............................9.4:1 Valve Train........................................DOHC, 16-Valve Fuel Induction System........................PGM-FI Ignition System..................................Electronic
DRIVE TRAIN Type.............................................. .. Front-Wheel Drive Manual Transmission........................ 5-Speed Automatic Transmission ....................4-Speed w/Sport-Shift Final Drive Ratio.............................. (MT/AT) 4.27/4.13 4.27/4.36(Si)
BODY/SUSPENSION/CHASSIS Body Type....................................... Unit Body Suspension....................................... 4-Wheel Upper Wishbone, Lower Control Arm Stabilizer Bar(mm, front/rear)........... 25.4/17.0 Steering Type.................................. Variable-Assist Power Rack-and-Pinion Steering Wheel Turns,Lock-to-Lock 2.81 4WS info NA Turning Diameter, Curb-to-Curb (ft.) 34.8 Brakes............................................ 4-Wheel Power-Assisted Disc Wheels........................................... 13-inch Steel Wheels w/Full Covers.......14-inch Steel Wheels w/Full Covers(Si) Tires............................................. .. 185/70 HR13....... 195/60 R14 85H(Si) Curb Weight(lbs., MT/AT).............. 2566/2606(2.0S)......2639/2674(2.0Si)........2690/2725(Si) Coefficient of Drag (Cd).................. .34
CAPACITIES Engine Oil with Filter (qt.)................. 5.1 Fuel (gal.)........................................ 15.9 Cooling System (qts., MT/AT)......... 6.3/5.6 6.7
4TH GENERATION Year '92-'96 (Si VTEC was introduced in '93)
Model S Si (SR in Canada) Si VTEC (SRV in Canada)
ENGINE S Type.............................................. . Aluminum-alloy in-line 4 Displacement................................... 2156 cc Horsepower@rpm (SAE net).......... 135@5200 Torque (lb.ft.).................................. 142@4000 Compression Ratio........................... 8.8:1 Valve Train...................................... SOHC, 16-Valve , Fuel Induction System...................... PGM-FI Ignition System................................ Electronic Sİ Type.............................................. . Aluminum-alloy in-line 4 Displacement................................... 2259 cc Horsepower@rpm (SAE net).......... 160@5800 Torque (lb.ft.).................................. 156@4500 Compression Ratio........................... 9.8:1 Valve Train...................................... DOHC 16-Valve Fuel Induction System...................... PGM-FI Ignition System................................. Electronic Sİ Vtec Type.............................................. .. Aluminum-alloy in-line 4 Displacement.................................... 2157 cc Horsepower@rpm (SAE net)........... 190@6800 Torque (lb.ft.)................................... 158@5500 Compression Ratio........................... 10.0:1 Valve Train....................................... DOHC 16-Valve VTEC Fuel Induction System....................... PGM-FI Ignition System................................. Electronic
DRIVE TRAIN Type.............................................. .. Front-Wheel Drive Manual Transmission........................ 5-Speed Automatic Transmission................... 4-Speed N/A Final Drive Ratio (MT/AT)................(S)4.06/4.29..... (Si)4.27/4.43...... (Si Vtec)4.27/NA
BODY/SUSPENSION/CHASSIS Body Type....................................... Unit Body Suspension....................................... 4-Wheel Upper Wishbone, Lower Control Arm Stabilizer Bar (mm, front/rear).......... 25.4/23.0 Steering Type.................................. Variable-Assist Power Rack-and-Pinion Steering Wheel Turns, Lock-to-Lock... 2.9 4WS info NA Turning Diameter, Curb-to-Curb (ft.)... 35.9 Brakes............................................ (S)4-Wheel Power-Assisted Disc...(Si & Si Vtec)4-Wheel Power-Assisted Disc w/ABS Wheels........................................... (S)14-inch Steel Wheels w/Full Covers..... (Si & Si Vtec)15-inch Alloy Wheels Tires............................................. .. (S)185/70 R14 87H (Si & Si Vtec)205/55 R15 87V Curb Weight (lbs., MT/AT)............. (S)2809/2862..........(Si)2866/2921..........(Si Vtec)2932/NA Coefficient of Drag (Cd).................. .33
CAPACITIES Fuel (gal.)........................................ 15.9
5TH GENERATION Year '97 -'01
Model Base.......97-98 SH.........97-98 Base.......99-01 SH.........99-01 SE.........01 (SE available in Canada only, SH not available in 01)
ENGINE Type............................................. Aluminum Alloy Inline 4 Displacement................................. 2157 cc Horsepower@rpm.....(Base,97-98)195@7000...(Base,99-01)200@7000...(SH,97-98)195@7000...(SH,99-01)200@7000 (Automatic)...................................(190 hp)^......................... (195hp)^ Torque (lb.ft.)............................... 156@5250 Compression Ratio....................... 10.0:1 Valve Train.................................. DOHC, 16-Valve VTEC Fuel Induction System.................. PGM-FI Ignition System............................ Electronic, w/ Immobilizer
DRIVE TRAIN Type........................................... .Front-Wheel Drive........................(SH)Front Wheel Drive w/ ATTS Manual........................................ Transmission 5-Speed Automatic Transmission............... 4-Speed w/Sequential Sport-Shift...(SH)N/A Final Drive Ratio......................... (MT/AT) 4.266/4.785...................(SH)4.266/NA
BODY/SUSPENSION/CHASSIS Body Type.................................. Unit Body Suspension.................................. 4-Wheel Upper Wishbone, Lower Control Arm Stabilizer Bar (mm, front/rear)..... (Base)25.4/23.0................... (SH)24.2/23.0 Steering Type.............................. Variable-Assist Power Rack-and-Pinion Steering Wheel Turns, Lock-to-Lock....... (Base)2.887............ (SH)2.762 Turning Diameter, Curb-to-Curb (ft.)........ (Base)36.1............. (SH)37.4 Brakes........................................ 4-Wheel Power-Assisted Disc w/ ABS Wheels....................................... 16-Inch Alloy Tires........................................... 205/50 R16 87V Curb Weight (lbs., MT/AT).........(Base) 2954/3009................ (SH)3042/NA Assembled in........................... Sayama, Japan
CAPACITIES Engine Oil with Filter (qt.)........... 5.1 Recommended Oil.......................SAE 5w30 Fuel (gal.).................................. 15.9
PERFORMANCE 1st Gen ('80) 0-60..............11.5 1/4 mile.........N/A 2nd Gen 0-60..............9.7. 1/4 mile.........17.2 3rd Gen (2.0 Si 4ws '88 ) 0-60.............9.3 1/4 mile........16.8 4th Gen ('92 Si 4ws) 0-60...........7.8 1/4 mile.......15.9 Top speed...130 4th Gen ('95 Si Vtec) 0-60............6.7 1/4 mile.......15.1@93mph 5th Gen ('99 manual) 0-60..........6.8 1/mile........15.4 5th Gen ('97 sportshift) 0-60..........7.8 1/mile........16.0@89 Top speed....143
PreludeBB2
« Yanıtla #1 : Aralık 09, 2005, 10:52:08 ÖS » |
Tolgacım çok güzel bir başlık altında süper faydalı ve bilgilendirici bir konu açmışsın. Seni tebrik ederim.
HONDA
« Yanıtla #2 : Aralık 10, 2005, 12:32:20 ÖS » |
Teşekkürler Tolga detaylı ve çok gerekli bilgiler...
Administrator.
SENSEI
Offline
Mesaj Sayısı: 6889
R 29110
« Yanıtla #3 : Aralık 14, 2005, 03:41:53 ÖS » |
guzel bilgiler..cok faydalı
Daniel Gabriel
« Yanıtla #4 : Aralık 18, 2005, 02:30:10 ÖÖ » |
Benim için büyük 1 zewk
prelude56
Honda City
Offline
Mesaj Sayısı: 64
« Yanıtla #5 : Ocak 05, 2006, 08:32:47 ÖS » |
92 model f20a4 motorun bilgileri varmı burada?
prelude güzelbir melodidir.
Daniel Gabriel
« Yanıtla #7 : Ocak 06, 2006, 10:07:05 ÖS » |
Konuyla ilgisiz mesajlar silinmiştir..
cuneytercan
« Yanıtla #8 : Ocak 19, 2006, 06:19:48 ÖS » |
Elimde 1997-1999 Prelude Service Manual var. Isteyenlere gonderebilirim[/list][/url]
Daniel Gabriel
« Yanıtla #9 : Ocak 19, 2006, 11:29:28 ÖS » |
Abi kitap halindemi war yoksa netten bulduun 1şeymi ??
cuneytercan
« Yanıtla #10 : Ocak 20, 2006, 03:32:43 ÖS » |
pdf formatinda, eskiden serviste calisan bir arkadastan almistim.
Daniel Gabriel
« Yanıtla #11 : Ocak 20, 2006, 03:52:57 ÖS » |
pdf formatinda, eskiden serviste calisan bir arkadastan almistim. Hmm..tamam ozaman.. Cüneyt abi buluşma bilgilerini "Prelude Owners" bölümünden takip edebilirsin..
aliosmancebel
« Yanıtla #12 : Mart 08, 2006, 05:22:34 ÖS » |
owners manuel süper bişi çok sağol o kadar aradım nette bulamadıydımm .... :-D
Daniel Gabriel
« Yanıtla #13 : Mart 19, 2006, 06:58:35 ÖS » |
owners manuel süper bişi çok sağol o kadar aradım nette bulamadıydımm .... :-D Rica ederiz nedemek :-D
Daniel Gabriel
« Yanıtla #14 : Mart 21, 2006, 05:57:18 ÖS » |
Çok güzel we faydalı bilgiler.. Eline sağlık Sercan.. :-D
aliosmancebel
« Yanıtla #15 : Mart 27, 2006, 05:52:47 ÖS » |
bu kadarmı bu bölüm başka bi bilgi edinemiyozmu...
Doganov
Honda City
Offline
Mesaj Sayısı: 54
« Yanıtla #16 : Haziran 18, 2007, 07:03:49 ÖS » |
eline sağlık gerçekten bilgiler süper.
DEACON FROST
Honda Jazz
Offline
Mesaj Sayısı: 1
« Yanıtla #17 : Ağustos 16, 2007, 10:19:22 ÖÖ » |
Merhaba Arkadaslar, ismim Alp, araniza yeni katıldım. Bende bir prelude kullanıcısı olmak istiyorum fakat bu harika makinanin yakit sarfiyatı ben cok dusundurmekte :  92 -93 Model serisiyle ilgileniyorum. eniyiyisi ben biraz daha forumları okuyayım bilgi sahibi olup buraya oyle yazayım soırularımı, belki cevabı vardir. Buarada yukarddaki yararli bilgileri veren arkadasada tesekkur ederm.
