Gönderen Konu: PRELUDE LERE SADECE 114,3 MÜ JANT OLUYOR?  (Okunma sayısı 8390 defa)
aliosmancebel
« : Mart 07, 2006, 10:32:35 ÖÖ »
YAW ÇOK KIL Bİ DURUM Bİ HEVES ETTİM 114,3 DEN BAŞKA JANT OLMUYOMUŞ NE SAÇMA ŞEY KIL OLDUM JAPONLARA...
Daniel Gabriel
« Yanıtla #1 : Mart 07, 2006, 10:36:05 ÖÖ »
Ewet 4x114.3..Maalesef çok bulunan 1 model değil  :-(
Tire Sizes
15” Rims
205/55 – OEM and recommended 15” size
205/50 - larger contact patch, slightly smaller diameter
215/50 - larger contact patch, diameter is slightly smaller
225/45 – 20mm larger contact patch, smaller diameter (some tire brands are slightly larger than 225. these may require 7” rims)
225/50 - 20mm larger contact patch, larger diameter (some tire brands are slightly larger than 225. these may require 7” rims)
16” Rims
205/50 – 5th Gen OEM and recommended 16” size
215/45 - larger contact patch
215/50 - larger contact patch, diameter is slightly larger
17” Rims
205/40 - 205 size is not recommended for tires over 7"
215/40 - larger contact patch, recommended tire size
215/45 - larger contact patch, diameter is slightly larger
225/40 – 20mm larger contact patch
18” Rims
215/35 - larger contact patch, consider for show use only (very little protection for your rims)
215/40 - larger contact patch, diameter is slightly larger
225/35 – 20mm larger contact patch, recommended tire size
Stockies
4th Gen = 6.5" wide rim 55mm
The 4th Gen comes stock w/ 205/55/15 tires
Offset
6.5" wide rims
Less than +38mm - Chance of rubbing the outside lip of the wheel well with this offset.
+38mm to +55mm - Recommended offset for 6.5" rims.
Larger than +55mm - Chance of rubbing the inside lining of the wheel well with this offset.
7" wide rims
Less than +38mm - Not suggested
+38mm to +41mm – Not suggested if you plan on lowering. Chance of rubbing the outside lip of the wheel well with this offset.
+42mm to +44mm – This may or may not work, depends on if you are lowered. Chance of rubbing the outside lip of the wheel well with this offset.
+45mm to +50mm - Recommended offset for 7" rims.
Larger than +51mm - Not suggested. Chance of rubbing the inside lining of the wheel well with this offset.
7.5" wide rims
Less than +40mm - Not suggested
+40mm to +43mm - This may or may not work, depends on if you are lowered. Chance of rubbing the outside lip of the wheel well with this offset.
+44mm to +47mm - This may or may not work, depends on if you are lowered. Chance of rubbing the outside lip of the wheel well with this offset.
+48mm to +52mm - Recommended Offsets for 7.5" rims.
Larger than +53mm - Not suggested. Chance of rubbing the inside lining of the wheel well with this offset.
Stock Lug Pattern
4th Generation - 4x114.3
PreludeBB2
  • İleti: 526
« Yanıtla #2 : Mart 07, 2006, 11:37:41 ÖÖ »
Tolga dostum çok süper bir jant - lastik ve offset bilgisi vermişsin. Sağolasın. Ali, G4 Preludelerde sadece 4 x 114.3 bijon aralıklı jantları kullanabilirsin. Ama bu bijon aralığında da baya bi kaliteli jantlar var. Ben aracı almadan ve aldıktan sonra epey bi araştırmıştım bu konuyu. Şu an benimkinin üzerinde aldığımda takılı olan 17" 4 x 114.3 Alessio Action var. Biraz para ayarladığım zaman alacağım jant Enkei RP03 dür mesela. Kaliteli ve hafif jantlardan Oz, Kosei, Enkei gibi markalara TR den ulaşabilirsin. Bunun dışındaki Racing Heart, Volk, GramLights, SSR gibi süper markalarda var ama bunların maalesef TR de dağıtıcısı yok. O yüzden Yurtdışından getirtmek gerek. 8)
aliosmancebel
teşekkürler
« Yanıtla #3 : Mart 07, 2006, 12:20:06 ÖS »
TAMAM O ZAMAN O İSTEDİĞİN JANTLARI ALINCA  ESKİLERİ ALIYIM UYGUN Bİ FİYAT SÖYLERSEN !!!
PreludeBB2
  • İleti: 526
Re: teşekkürler
« Yanıtla #4 : Mart 07, 2006, 01:28:29 ÖS »
Alıntı yapılan: "aliosmancebel"
Olur tabi dostum. Ama Benim daha jant almama epey bi zaman var. :-(  Malum aracın borcunu ödüyorum şu anda ve diğer öncelikli masraflardan janta sıra biraz daha sonra gelecek.
aliosmancebel
« Yanıtla #5 : Mart 07, 2006, 03:15:56 ÖS »
kaça aldın sen jant lastik komple !
tolgabin
« Yanıtla #6 : Mart 07, 2006, 03:36:55 ÖS »
benim arabada da 4x114.3 (98 accord)
fikir olsun ben baya aradıktan sonra OZ 'in titan modelini aldım 16 inç.
tolgabin
« Yanıtla #7 : Mart 07, 2006, 03:40:06 ÖS »
buda arabanın üstündeki resim resim çok iyi değil kusura bakmayın :-D
PreludeBB2
  • İleti: 526
« Yanıtla #8 : Mart 07, 2006, 04:31:35 ÖS »
Dostum Ben aldığımda Alessio lar üzerindeydi. O yüzden janta pek masraf etmedim. Sadece biraz yamuklukları vardı onları düzelttirdim Tornada. Bi 60 YTL civarına geldi düzeltim işlemi. Lastiklere gelince de aldığımda üzerinde olan Marangoni Zetalarda balon vardı. Onları atıp 215-40-ZR17 Kumho Ecsta SPT aldım. Lastikler öndüzen ayarlarıyla felan yaklaşık 700 YTL civarına mal oldu.
Maverick
« Yanıtla #9 : Mart 07, 2006, 10:47:34 ÖS »
peki spacer kit kullanarak istediğin jantı takma şansın yokmu?.bildiğim kadarıyla kullanılan spacer kit'ler lastiği biraz dışarı alıp aks mesafesini uzatıyor ki böylece yol tutuş artıyor artı birde istediğin jantı takmana izin veriyormuş diye okumuştum acaba varmı kullanan aramızda yada bilgisi olan birileri?
PreludeBB2
  • İleti: 526
« Yanıtla #10 : Mart 07, 2006, 11:08:21 ÖS »
Valla benim bildiğim spacer sadece lastiği biraz daha ileri almaya yarıyor. Çünkü akstan direk olarak geliyor o saplamalar. 4 tane olan saplamaları 5 adet yapmak için anca aks uçlarını, yani jantın ve fren disklerinin oturduğu kısmı komple değiştirmek gerek. Bu da ne kadar sağlıklı olur bilemiyorum. :?
Maverick
« Yanıtla #11 : Mart 08, 2006, 12:06:21 ÖÖ »
Alıntı yapılan: "PreludeBB2"
yok hayır işte bu ayki trtuning'de yazıyordu cms araçlara özel kit getirtmiş ister 5 bijonu 4'e,4'üde 5'e çevirebiliyormuş yada 4*120 yi 4*98'e çevirebiliyormuş.
PreludeBB2
  • İleti: 526
« Yanıtla #12 : Mart 08, 2006, 12:17:57 ÖÖ »
Alıntı
Hmmm.. O zaman güzelmiş yaw. Performans ve sağlamlık yönünden de bi problem olmuyorsa süper bir şey hatta. Bugün dergiyi aldım elime alayım mı almayayım mı dedim. Sonra da almadım. Bi ara alıp bakayım bende o zaman.
Maverick
« Yanıtla #13 : Mart 08, 2006, 11:50:18 ÖÖ »
pazar gunu draglara gelıceksen getırırım orada gorusruz ıstersen hem tanısmıs oluruz
PreludeBB2
  • İleti: 526
« Yanıtla #14 : Mart 08, 2006, 11:54:34 ÖÖ »
Alıntı yapılan: "Maverick"
Pazarları çalışıyorum maalesef dostum :-( Ama düşünmen bile yeter, çok sağolasın. Bende isterim en kısa sürede tanışmayı. İnşallah ilk müsait olduğumuz zamanda görüşürüz. :-)
Daniel Gabriel
« Yanıtla #15 : Mart 08, 2006, 11:54:52 ÖÖ »
oooooooooo..Ozan walla İstanbul'da olsan manyak olurdu  :-D  :-D
PreludeBB2
  • İleti: 526
« Yanıtla #16 : Mart 08, 2006, 12:16:10 ÖS »
Alıntı
Evet Tolgacım, İstanbul'un özel bir yeri var zaten benim için. Sonuçta aracı aldığım yer. Parayı bulayım biraz mod parçaları almak için gelmek isterim gene. :-) Ne güzeldi DivanCity İstanbul daki odam... :D
aliosmancebel
« Yanıtla #17 : Mart 08, 2006, 02:16:01 ÖS »
yeni jant alıpta eskisini vermeyi düşünen varsa haberimiz olsun... ön tampon altındaki siyah parçadan nerde bulabilirim... ?
PreludeBB2
  • İleti: 526
« Yanıtla #18 : Mart 08, 2006, 09:54:55 ÖS »
Bana da lazım o tampon altı süpürgelik den dostum. Ama sadece servisten bulabiliriz gibime geliyor o parçayı.
aliosmancebel
« Yanıtla #19 : Mart 09, 2006, 10:06:57 ÖÖ »
OOOOOOOOO servise sadece o parça içinde gitmem üzerler adamı başlarlar gene japonyadan gelcek diye  :lol:  bak benim aklımda projeler var hayata geçirirsem paylaşacam herkesle kendi süpürgeliğini kendin yap kampanyası..... çalışmalar sürüyor ...
PreludeBB2
  • İleti: 526
« Yanıtla #20 : Mart 09, 2006, 06:43:31 ÖS »
Hadi bakalım dostum, merakla bekliyoruz projelerini. :-)
