Honda Prelude Type SBodywork Type: 2+2 FHC
Number of doors: 2
Dimensions Wheelbase: 2585 mm 101.77 in
Track front: 1525 mm 60.03 in
Track rear: 1515 mm 59.64 in
Length: 4520 mm 177.95 in
Width: 1750 mm 68.89 in
Ground clearance: 140 mm 5.51 in
Kerb weight: 1310 kg 2888.05 lb
Fuel capacity: 60 l 15.85 US gal
Engine Manufacturer: Honda
Type: S-4
DOHC
16 valves total
4 valves per cylinder
Main bearings: 5
Bore x stroke: 87.00mm × 90.70mm
Bore / stroke ratio: 0.96
Displacement: 2157 cc 131.62 cu in
Compression: 11.00:1
Fuel system: Honda PGM-FI fuel inj.
Aspiration: Normal
Catalytic Converter: Y
Max. output: 223.1 PS (220.0 bhp) (164.1 kW)@7200 rpm
Max. torque: 221.0 Nm (163 lbft) (22.5 kgm)@6500 rpm
Coolant: Water
Specific output: 102 bhp/litre
Specific torque: 102.46 Nm/litre
Performance
Power to weight: 167.94 bhp/ton
Chasis Engine location: Front
Engine alignment: Transverse
Turning circle: 11.00 m
Transmission: 5M
Drive: FWD
Top gear ratio: 0.81
Final drive ratio: 4.27
