94-96 (GSR) B18C Engine
Swap: $3085.00
-Only long blocks in stock currently $1850.00 & Completes w/ LSD $3300.00
• 1800cc (1.8L) DOHC Vtec engine.
• 180hp/126trq, 10.6 compression ratio. (U.S. version has 170hp and 10.1
cr.)
• Hydro tranny type.
• P72 OBD-1 or OBD-2 ECU equipped.
• Inquire within for LSD equipped trans. (not all trans are LSD equipped).
• U.S. version of this engine is available. Also, specify which year type
you need (OBD-1/2).
97-00 (GSR) B18C Engine
Swap: $3600.00
-Out of stock
• 1800cc (1.8L)DOHC Vtec engine.
• 180hp / 126trq / 10.6 compression ratio. (U.S. version has 170hp and
10.1 cr.) • Hydro tranny type.
• U.S. version of this engine is available.. Also, specify which year type
you need (OBD-1/2).
94-98 Integra Type- R Engine
Swap: $4800.00
-Out of stock
• 200hp / 18.5Nm trq / 11.1 cr., DOHC Vtec (U.S. version is 195hp/10.6
cr.)
• Integra-R P73 OBD-2 ECU type.
• We have access to U.S. version Integra Type-R engine's as well.
94-98 Civic R (B16B) Engines
Swap: $4600.00
-Out of stock
• 185 hp / 118 trq / 10.8 cr., DOHC Vtec Engine.
• Civic-R PCT OBD-2 ECU type.
92-95 Prelude H22A Engine
Swap: $2250.00
• 2200cc (2.2L) DOHC Vtec Engine
• 200hp / 161trq / 10.6:1 cr.
• Hydraulic tranny type
• Inquire within if you desire the U.S. version of the this engine.
96-00 Prelude H22A Engine
Swap: $3100.00
-Out of stock
• 2200cc(2.2L) DOHC Vtec.
• Inquire within if you prefer the U.S. version of the this engine.
Enjoy the Speed!*!
http://www.jaydm.com/jdm.htm
