Selam arkadaslar Su ikisi hakkinda yorumlarinizi almak istiyorum... Alicam ama karar veremiyorum pek bilgim yok bu konularda...
Model KICKER CVR15http://www.kicker.com/compvrSize (IN.,CM) 15, 38.0
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 1000/500
Sensitivity (dB 1w/1m) 89.2
Frequency Response (Hz) 25-500
Mounting Depth (IN.,CM) 8 3/16, 20.7
Mounting Cutout (IN.,CM) 13 11/16, 34.7
Min Rec Sealed Box Volume (CU. FT., Liters) 1.8, 51
Max Rec Sealed Box Volume (CU. FT., Liters) 5.2, 147
Min Rec Vented Box Volume (CU. Ft., Liters)** 3, 85
Max Rec Vented Box Volume (CU. Ft., Liters)** 5, 142
Model KICKER ZX500.1http://www.kicker.com/ZX_AmplifiersClass D
Power (watts) Mono 500 @ 2 Ohms
Remote Bass Control No
ZXRC Remote Bass capable (sold sep.) Yes
Length (in., mm) 12", 305mm
Common to all Models
Height: 2-1/8", 54mm
Width: 9-5/8", 244mm
Frequency Response: 25-200Hz (ZX300.1 25-20kHz), +0/-1dB
Input Sensitivity: High Level 250mV-10V, Low Level 125mV-5V
Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
Active Crossover: 24dB/octave, variable 50Hz-200Hz (ZX300.1 fixed at 80Hz), low pass only
24dB/octave high-pass subsonic filter fixed @ 25Hz
KICKEQ™ Boost: Variable to +18dB (ZX300.1 selectable +12dB), centered @ 40Hz
