Merhaba arkadaslar benim size sorum var.... Internetten biraz baktim. Turkiyedeki 92-95 arasi civiclerde D16A9 Motor oldugu gozukuyor. Peki bu motorlar VTEC mi? Viki'den baktim fakat sonuc NON-VTEC sanirim.
D16A9
(Same as D16A8 but without a catalytic converter)
Found in:
1988–1991 Concerto (UK/Europe)
1988–1991 CRX 1.6i-16(UK/Europe/South Africa)
1990–1992 Ballade 160i-DOHC (South Africa)
1988–1991 Civic 1.6i-16(UK/Europe)
1992–1993 Civic GTi (New Zealand)
1989–1992 Rover 216/416 GTi (UK/Europe)
1992–1995 Civic Si (Japanese, European and Peruvian version)
Displacement : 1,598 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Compression : 9.5:1
Power : 130-137 hp (96.9-102.1 kW, 132-140 PS) at 6,800 rpm
Torque : 105 lb·ft (14.5 kg/m, 143 Nm) at 5,700 rpm
Valvetrain : 16 valve (4 valves per cylinder)
Redline: 7,200 rpm
Limit: 7,250 rpm
Fuel Cut: 7800 RPM (PM7)
Fuel Control : 88-91 OBD-0 MPFI (92-95 OBD-1)
ECU Code: PM7 (P29 OBD1)
GearBox : <non LSD> (88-91 L3) (LSD 92- 95 S20)
