Gönderen Konu: 2003 CRV TEKNİK ÖZELLİKLER KULLANIM KİTABI  (Okunma sayısı 2475 defa)
thesunset1983
  • İleti: 13
« : Aralık 15, 2009, 08:53:27 ÖS »
ARKADAŞLAR YENİ ALDIĞIMIZ 2003 CRV MİZİN TEKNİK ÖZELLİKLERİ VE KULLANIM KİTAPÇIĞI HAKKINDA YARDIM LÜTFEN...
endlessnihilist
  • İleti: 251
Ynt: 2003 CRV TEKNİK ÖZELLİKLER KULLANIM KİTABI
« Yanıtla #1 : Aralık 18, 2009, 02:35:36 ÖS »
selamlar, aracınız hayırlı olsun.
internetten buldum bilgileri tamamen alıntıdır. fakat kullanım kitapçığı hakkında fikrim yok. kolay gelsin.
2003 Honda CR-V Performance
- 2,354 cc 2.4 liters in-line 4 front engine with 87 mm bore, 99 mm stroke, 9.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
- Unleaded fuel
- Fuel economy EPA highway (mpg): 26 and EPA city (mpg): 22
- Multi-point injection fuel system
- 15.3 gallon main unleaded fuel tank
- Power: 119 kW , 160 HP SAE @ 6,000 rpm; 162 ft lb , 220 Nm @ 3,600 rpm
    2003 Honda CR-V Handling
- 4.77:1 axle ratio
- Four disc brakes including two ventilated discs
- Immobilizer
- Fullsize steel rim rear spare carrier spare wheel
- Strut front suspension independent with stabilizer bar and coil springs , wishbone rear suspension independent with stabilizer bar and coil springs
    2003 Honda CR-V Exterior
- Body side molding
- Black front and rear bumpers
- Driver and passenger power black door mirrors
- External dimensions: overall length (inches): 178.6, overall width (inches): 70.2, overall height (inches): 66.2, ground clearance (inches): 8.1, wheelbase (inches): 103.1, front track (inches): 60.4, rear track (inches): 60.6 and curb to curb turning circle (feet): 34.1
- Complex surface lens halogen bulb headlights
- Heat reflective glass
- Gloss paint , black paint , metallic paint , pearl paint
- Hinge rear window with defogger and intermittent
- Roof rails
- Tinted glass on cabin, rear and side
- Underbody protection for engine
- Weights: gross vehicle weight rating (lbs) 4,320, curb weight (lbs) 3,318, gross trailer weight braked (lbs) 1,500 and max payload (lbs) 1,062
- Windshield wipers with fixed intermittent wipe
    2003 Honda CR-V Interior
- 12v power outlet: front & cargo
- Air conditioning
- Fixed mast antenna
- Audio anti-theft protection: code
- Audio system with AM/FM radio, CD player and cassette
- Below seat storage under passenger seat
- Cargo area light
- Cargo capacity: rear seat down (cu ft): 72 and all seats in place (cu ft): 33.5
- Clock
- Full dashboard console with covered storage box , partial floor console with open storage box , partial overhead console with covered storage box
- Delayed/fade courtesy lights
- Cruise control
- Front seats and rear seats cup holders
- Door ajar warning
- Door pockets/bins for driver seat, passenger seat and rear seats
- Floor covering: carpet in load area
- Floor mats
- Driver and passenger front airbag with occupant sensors
- Bucket driver seat with height adjustment , bucket passenger seat
- Height adjustable 3-point reel front seat belts on driver seat and passenger seat with pre-tensioners
- Front seat center armrest
- Lockable glove compartment
- Two height adjustable head restraints on front seats , three height adjustable head restraints on rear seats
- Internal dimensions: front headroom (inches): 40.9, rear headroom (inches): 39.1, front hip room (inches): 54.5, rear hip room (inches): 53.5, front leg room (inches): 41.3, rear leg room (inches): 39.4, front shoulder room (inches): 56.9, rear shoulder room (inches): 56.5 and interior volume (cu ft): 106
- Low fuel level warning
- Key power locks includes trunk/hatch
- Vehicle speed proportional power steering
- Front power windows with one one-touch , rear power windows
- Front reading lights
- 3-point reel rear seat belts on driver side, passenger side and center side
- Rear seat center armrest
- Three asymmetrical split bench front facing reclining removable rear seats with fore/aft adjustment and zero adjustments
- Rear view mirror
- Remote fuel filler door release
- Electric remote trunk/hatch release
- Front seat back storage
- Cloth seat upholstery with additional cloth
- Seating: five seats
- Service interval indicator
- Front side airbag with occupant sensors
- Four speaker(s)
- Plastic multi-function steering wheel with tilt adjustment
- Tachometer
- Driver and passenger vanity mirror
- Ventilation system with recirculation setting and micro filter
