Displacement : 1,590 cc
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Compression : 9.4:1
Power : 120 hp (88.0 kW) @ 6400 rpm
Torque : 144 nm / 5000rpm
Redline : 6800 rpm
Rev-limiter: 7200 rpm
Fuel Control : OBD-2 MPFI
Head Code : P2A-2
ECU Code : P2K
Rod /Stroke Ratio : 1.52
Rod Length : 152 mm
Deck Height : 212
Gear Ratios:
1st 3.250 2nd 1.909 3rd 1.250 4th 0.909 5th 0.702 rev 3.153 final 4.058
