Gönderen Konu: +02 Civic Type R için Modifiye Parçaları ve Fiyatları  (Okunma sayısı 2042 defa)
HONDA
« : Şubat 22, 2006, 12:42:27 ÖS »
Fiyatlar İngiliz Sterlini cinsindendir...
22 Şubat 2006
Air Filters
AEM long ram cold air induction system  £188.94
GruppeM carbon fibre induction kit  £413.00
The GruppeM carbon fibre induction kit replaces the standard airbox system.
HKS 'Super Power Flow' induction kit  £155.00
HKS 'Super Power Flow' induction kit.
K & N Air Filter  £48.00
Direct replacement in the standard airbox.
Mugen carbon air box  £445.06
Spoon air filter  £99.47
Direct replacement in standard airbox.
Brakes
EBC turbo groove front brake disc  £95.00
EBC turbo groove front brake disc.
EBC turbo groove rear brake disc  £60.00
EBC turbo groove rear brake disc.
Ferodo DS2500 front brake pads  £70.04
The Ferodo DS2500 front brake pads provide a good balance between fast road and track use.
Ferodo DS2500 rear brake pads  £61.86
The Ferodo DS2500 rear brake pads provide a good balance between fast road and track use.
Goodridge brake line kit  £65.00
Goodridge brake line kit (4 pieces).
Spoon bracket set for monoblock calipers  £113.68
Spoon bracket set for monoblock calipers.
Spoon brake lines  £255.79
Spoon brake lines.
Spoon brake pads  £142.11
Spoon brake pads.
Spoon mono block calipers  £1,136.84
Spoon mono block calipers, 2.1kg lighter than standard calipers.
Drive Train
Nu-Speed quick shift kit  £85.00
The Nu-speed quick shift kit with a 20% reduction
Quaife LSD unit  £475.00
Quaife LSD unit
Spoon LSD unit  £696.32
Spoon LSD unit.
Spoon clutch slave hose  £63.95
Spoon clutch slave hose.
TODA Hi-power clutch & flywheel kit  £700.00
TODA Hi-power clutch & flywheel kit.
TODA light weight flywheel  £295.00
TODA light weight flywheel (3.78kg).
TODA racing ceremetallic clutch  £405.00
TODA ceremetallic clutch.
Electronics
Blitz 'Power Meter' ID3  £185.00
The Blitz power meter ID3 is a multi-functional chasis dyno metre.
Blitz R-VIT data monitor  £295.00
HKS circle earth system  £135.13
HKS circle earth system.
Hondata ECU Upgrade (Euro K Pro)  £628.08
This is the latest generation of ECU released by Hondata, fully reprogrammable through its windows based software.
Hondata ECU Upgrade (US K Pro)  £1,162.32
O2 Sim   £55.32
O2 Sim for use with racing manifolds
Spoon earthing system  £85.26
Spoon earthing system.
Engine Components
HKS 'Superfire' spark plug  £14.50
HKS 'Superfire' spark plug.
Heat resistant barrier tape  £15.00
Heat resistant barrier tape universal fitting.
Hondata Heatshield Gasket  £50.22
The Hondata heatshield gasket is a special high temperature insulating gasket.
JDM Inlet manifold (PRC)  £305.39
The JDM Inlet manifold improves top end air flow, from 7,300 rpm.
Mugen low temperature fan switch  £38.24
Mugen low temperature thermostat  £63.55
Samco silicon hoses  £48.00
Samco silicon coolant hose kit (2 pieces).
Spoon 'Street' aluminium radiator  £568.42
Spoon 'Street' aluminium radiator.
Spoon Throttle body assembley  £341.05
Spoon throttle body assembley.
Spoon baffled oil sump pan  £373.00
Spoon baffled oil sump pan.
Spoon high pressure radiator cap  £19.18
Spoon high pressure radiator cap.
Spoon magnetic oil drain plug  £24.16
Spoon magnetic oil drain plug.
Spoon oil cap  £46.18
Spoon billet alloy oil cap.
Spoon radiator bracket and titanium bolt  £21.32
Spoon radiator bracket and titanium bolt, 43g lighter than standard.
Spoon thermostat switch  £48.32
Spoon thermostat switch.
TODA 2.2 stroker kit  £2,560.00
TODA high compression forged piston kit  £615.00
TODA racing spec A2 camshaft and valve spring kit  £1,045.00
TODA racing A2 camshaft and valve spring kit.
TODA racing spec A3 camshaft & valve spring kit  £1,045.00
TODA racing spec N2 camshaft and valve spring kit  £1,045.00
TODA racing thin steel head gasket  £135.00
TODA racing special thin (0.6mm) steel head gasket.
Up-rated engine mounts  £30.00
Exhausts
DC Sports exhaust manifold (Brushed finish)  £344.70
DC Sports 4-2-1 exhaust manifold (Brushed finish)
Jackson Racing exhaust manifold  £475.00
Jackson Racing 4-2-1 polished stainless steel exhaust manifold.
Spoon 'N1 Muffler' exhaust system  £518.68
This system is 4.4kg lighter than the standard system. With a 65mm tailpipe.
Spoon 4-2-1 exhaust manifold  £888.16
Spoon 4-2-1 polished stainless steel exhaust manifold.
TODA Exhaust Manifold  £700.00
Toda 4-2-1 polished stainless steel exhaust manifold.
TODA Hi-power exhaust system  £645.00
TODA Hi-power exhaust system.
TRUST/GReddy 'Evolution' exhaust system  £445.00
TRUST/GReddy 'Evolution' exhaust system. With a 100mm tailpipe.
Interior
Spoon Titanium gear knob  £69.63
Suspension
Adjustable rear camber arm  £65.00
The adjustable rear arm replaces the standard one and allows precise camber adjustment.
J's Racing front strut brace with torque damper  £239.00
J's Racing front upper strut brace with torque damper
J's Racing upper front strut brace  £160.00
The J's Racing front upper strut brace improves body stiffness and steering stability.
JDM Front anti-roll bar  £70.50
The JDM Front ant-roll bar must be used when fitting the Toda exhaust manifold.
JDM Rear anti-roll bar  £70.50
The JDM rear anti-roll bar improves road holding and rear end lift.
Spoon adjustable damper kit  £1,563.16
Spoon adjustable damper kit.
Spoon fixed damper kit  £582.63
Spoon fixed damper kit.
Spoon lower front arm bar  £85.26
Spoon lower front arm bar.
Spoon lower rear arm bar  £85.26
Spoon lower rear arm bar.
Spoon progressive spring set  £198.95
Spoon progressive spring set. Lowers car by 25mm.
Spoon upper front strut brace  £113.68
Spoon upper front strut brace.
Spoon upper rear strut brace  £99.47
Spoon upper rear strut brace.
Tein 'EDFC' kit  £220.00
Tein 'EDFC' (Electronic Damping Force Controller) kit.
Tein 'Super Street' fully adjustable kit  £770.00
Tein 'Super Street' fully adjustable kit with upper mounts
Tein 'Super Street' fully adjustable kit  £540.00
Tein 'Super Street' fully adjustable kit without upper mounts
Tuning Kits
Jackson Racing Supercharger kit (for K Pro owners)  £1,868.60
Jackson Racing Supercharger kit  £2,511.68
The Jackson Racing supercharger kit includes all the necessary components for a complete installation.
Trust/Greddy turbocharger kit  £2,850.00
The Trust/Greddy turbocharger kit includes E-manage ECU and bigger injectors.
Wheels
Spoon alloy wheel nut  £4.26
Spoon alloy wheel nut, 10.5g lighter than standard wheel nut.
aSil
  • İleti: 989
« Yanıtla #1 : Şubat 22, 2006, 02:41:32 ÖS »
Süper abi saolasın bilgiler için.
poşetçay
Ynt: +02 Civic Type R için Modifiye Parçaları ve Fiyatları
« Yanıtla #2 : Ekim 09, 2009, 11:43:41 ÖÖ »
güncel
