Administrator.
SENSEI
Offline
Mesaj Sayısı: 6978
R 29110
« : Ekim 24, 2006, 08:24:24 ÖS » |
K20A• Found in: o 2002-2005 Honda Civic Type-R (EP3) o 2001-2006 Honda Integra Type-R(DC5) • Displacement: 1998 cc • Compression: 11.5:1 • Power: 220 hp (162 kW) @ 8000 rpm • Torque: 152 ft•lbf (206 N•m) @ 7000 rpm • Redline: 8500 rpm o 2003-2006 Honda Accord Euro-R • Displacement: 1998 cc • Compression: 11.5:1 • Power: 220 hp (162 kW) @ 8000 rpm • Torque: 152 ft•lbf (206 N•m) @ 7000 rpm • Redline: 8500 rpm
K20A2• Found in: o 2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP, European) • Displacement: 1998 cc • Compression: 11.0:1 • Power: 200 hp (149 kW) @ 7400 rpm • Torque: 142 ft•lbf (193 N•m) @ 6000 rpm • Redline: 7900 rpm
K20A3• Found in: o 2002-2005 Honda Civic Si • Displacement: 1998 cc • Compression: 9.8:1 • Power: 160 hp (119 kW) @ 6500 rpm • Torque: 132 ft•lbf (179 N•m) @ 5000 rpm • Redline: 6800 rpm o 2002-2006 Acura RSX • Displacement: 1998 cc • Compression: 9.8:1 • Power: 160 hp (119 kW) @ 6500 rpm • Torque: 141 ft•lbf (191 N•m) @ 4000 rpm • Redline: 6800 rpm
K20Z1 • Found in: o 2005-2006 Acura RSX-S • Displacement: 1998 cc • Compression: 11.0:1 • Power: 201 hp (150 kW) @ 7800 rpm (sae NET Rev 8/04) • Torque: 140 ft•lbf (194 N•m) @ 7000 rpm (sae NET Rev 8/04) • Redline: 8400 rpm
K20Z2• Found in: o 2006- Acura CSX (Canada) • Displacement: 1998 cc • Compression: 9.6:1 • Power: 155 hp (114 kW) @ 6000 rpm (sae NET Rev 8/04) • Torque: 139 ft•lbf (188 N•m) @ 4500 rpm / 188 N•m @ 4200 rpm (Singapore) • Redline: 6800 rpm o 2006- Honda Civic (JDM) • Displacement: 1998 cc • Compression: 9.6:1 • Power: 155 hp (114 kW) @ 6000 rpm • Torque: 139 ft•lbf (188 N•m) @ 4500 rpm • Redline: 6800 rpm
K20Z3• Found in: 2006 Honda Civic Si • Displacement : 1998 cc • Compression : 11.0:1 • Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04) • Torque: 139 lb•ft (189 N•m) @ 6200 rpm (sae NET Rev 8/04) • Redline: 8000 rpm
K23
K23A1• Turbocharged • Found in: o 2007 Acura RDX • Displacement: 2300 cc (acura.com) • Compression: 8.8:1 (acura.com) • Power: 238 hp @ 6000 rpm (SAE net) • Torque: 260 ft•lbf @ 4500 rpm (SAE net) • Redline: 6800 (acura.com) • Bore: 86 mm • Stroke: 99 mm K24
K24A1• Found in: o 2002-2006 Honda CR-V • Displacement: 2354 cc • Compression: 9.6:1 • Power: 160 hp (119 kW) @ 6000 rpm • Torque: 162 ft•lbf (220 N•m) @ 3600 rpm • Redline: 6500 rpm
K24A2• Found in: o 2004-2006 Acura TSX • Displacement: 2354 cc • Compression: 10.5:1 • Power: 205 hp (149 kW) @ 6800 rpm • Torque: 166 ft•lbf (225 N•m) @ 4500 rpm • Redline: 7100 rpm
K24A3• Found in: o 2003-2006 Honda Accord (Europe, Japan, and Australia) • Displacement: 2354 cc • Compression: 10.5:1 • Power: 189 hp (140 kW) @ 6800 rpm • Torque: 164.5 ft•lbf (223 N•m) @ 4500 rpm • Redline: 7000 rpm
K24A4• Found in: o 2003-2005 Honda Accord, 2003-2006 Honda Element • Displacement: 2354 cc • Compression: 9.7:1 • Power: 160 hp (119 kW) @ 5500 rpm • Torque: 161 ft•lbf (218 N•m) @ 4500 rpm • Redline: 6500 rpm
K24A8• Found in: o 2006/2007 Honda Accord • Displacement: 2354 cc • Bore and Stroke: 87 mm * 99 mm (3.43x3.90 inches) • Compression: 9.7:1 • Power: 166 hp (124 kW) @ 6000 RPM • Torque: 160 ft•lbf @ 4000 rpm • Redline: 6500 rpm
Administrator.
SENSEI
Offline
Mesaj Sayısı: 6978
R 29110
« Yanıtla #1 : Ekim 24, 2006, 08:27:32 ÖS » |
CHASSIS, POWER, REDLINE, C/R, BORE X STROKE, SIZE, TRANSMISSION
K20A (PRC/RBC) 2002+ Integra Type-R/Accord Euro-R (Japan) 220hp @ 8000rpm / 21kgm @ 7000rpm 8400rpm 11.5:1 86mm x 86mm 1998cc 6 Speed Manual (helical LSD)
K20A2 (PRB) 2002-2004 RSX Type-S (DC5) 200hp @ 7400rpm / 142lb-ft @ 6000rpm 7900rpm 11.0:1 86mm x 86mm 1998cc 6 Speed Manual
K20A3 (PND/PNF) 2002+ Civic Si (EP) / base RSX (DC5) 160hp @ 6500rpm / 141lb-ft @ 4000rpm 6800rpm 9.8:1 86mm x 86mm 1998cc 5 Speed Manual
K20C 2002+ Civic Type-R (EP Euro/Japan) 215hp @ 8000rpm / 20kgm @ 7000rpm 8400rpm 11.0:1 86mm x 86mm 1998cc 6 Speed Manual (helical LSD)
K20Z3 2006 Civic Si coupe (FG) 197hp @ 7800rpm / 139lb-ft @ 6200rpm 8500rpm 11.0:1 86mm x 86mm 1998cc 6 Speed Manual (helical LSD)
K24A1 (PPA) 2002-2004 CR-V (LRD) 160hp @ 6000rpm / 162lb-ft @ 3600rpm 6500rpm 9.6:1 87mm x 99mm 2354cc 5 Speed Manual (FWD/AWD)
K24A2 (RBB) 2002+ TSX (CL) 200hp @ 6800rpm / 166lb-ft @ 4500rpm 7100rpm 10.5:1 87mm x 99mm 2354cc 6 Speed Manual
K24A3 (RAA) 2002-2004 Accord (CE) 160hp @ 5500rpm / 161lb-ft @ 4500rpm 6500rpm 9.7:1 87mm x 99mm 2354cc 5 Speed Manual
K24A4 (PZD) 2002+ Element 160hp @ 5500rpm / 161lb-ft @ 4500rpm 6500rpm 9.7:1 87mm x 99mm 2354cc 5 Speed Manual (FWD/AWD)
Onu-R
« Yanıtla #2 : Ekim 24, 2006, 08:38:05 ÖS » |
K20A JDM type-R da olan motorun kodu değil mi? A2 olan da ülkemizde bulunan type-R'ların (yani EDM)
Onur YAŞAR Mazda Lantis 1.8 34 AAY 87 İKÜ  &
Administrator.
SENSEI
Offline
Mesaj Sayısı: 6978
R 29110
« Yanıtla #3 : Ekim 24, 2006, 08:39:51 ÖS » |
evet Onur.
Onu-R
« Yanıtla #4 : Ekim 24, 2006, 08:48:43 ÖS » |
Tamam abi saolasın, paylaşım için de saol buarada... K23A1 ilgimi çekti ya  Değişik..
Administrator.
SENSEI
Offline
Mesaj Sayısı: 6978
R 29110
« Yanıtla #5 : Ekim 24, 2006, 08:53:43 ÖS » |
K23A1 ilgimi çekti ya  Değişik.. ağzın sulanmasın  malesef USDM
Onu-R
« Yanıtla #6 : Ekim 24, 2006, 09:22:15 ÖS » |
Eheheh yok abi sulanmadı ya, 2.3 litre turbo motor 238 beygir üretmiş, redline 6800 devir falan, bana göre değil, K20A2 ye taksak turboyu olmuyor mu
aSil
Honda Prelude
Offline
Mesaj Sayısı: 1285
No speed, just drift!
« Yanıtla #7 : Ekim 25, 2006, 12:08:27 ÖÖ » |
Değerli bilgiler. Paylaşım için teşekkürler...
Tolga-R
Honda Civic VTI
Offline
Mesaj Sayısı: 397
« Yanıtla #9 : Ekim 25, 2006, 12:52:11 ÖÖ » |
peki bişey sorucam k20a2 nin sıkıştımasını 11.5.1 yaparsak + yazılım ile 20hp alabilirmiyiz. JDM olurmu yani
 __
Administrator.
SENSEI
Offline
Mesaj Sayısı: 6978
R 29110
« Yanıtla #10 : Ekim 25, 2006, 01:32:41 ÖÖ » |
k20a2 hondata beyinle JDM oluyor
Tolga-R
Honda Civic VTI
Offline
Mesaj Sayısı: 397
« Yanıtla #11 : Ekim 25, 2006, 01:39:35 ÖÖ » |
peki hondata nın yanında sıkıştırma 11.5 yapılırsa ne olur ?
 __
Administrator.
SENSEI
Offline
Mesaj Sayısı: 6978
R 29110
« Yanıtla #12 : Ekim 25, 2006, 01:54:30 ÖÖ » |
dikkat edersen JDM ve EDM type r dada bore-stroke oranları aynı, sıkıstırmadaki fark piggy back ayarlarla yapılabiliyor zaten..
Administrator.
SENSEI
Offline
Mesaj Sayısı: 6978
R 29110
« Yanıtla #13 : Ekim 25, 2006, 01:58:56 ÖÖ » |
şunuda ilave etmek isterim; üst kapak conta (headgasket) değşimi, piston kafalarının ve yuvalarının polishi ve yuksek basınca musade eden pistonlarlada sıkıştırmaya etki edebilirsin..
R-13239
« Yanıtla #14 : Ekim 25, 2006, 04:25:17 ÖÖ » |
Teşekkürler abi paylaşım için , hakkaten süper bilgiler..
SKUNKSTER
Honda City
Offline
Mesaj Sayısı: 78
« Yanıtla #17 : Aralık 14, 2006, 01:59:13 ÖÖ » |
peki bişey sorucam k20a2 nin sıkıştımasını 11.5.1 yaparsak + yazılım ile 20hp alabilirmiyiz. JDM olurmu yani  çok daha fazlasini da alirsin
type-RRR
« Yanıtla #18 : Aralık 14, 2006, 12:21:49 ÖS » |
paylaşım için tşk
serkan
« Yanıtla #19 : Aralık 14, 2006, 01:51:00 ÖS » |
Hepsi varda bi K20A6 yok be tühh
