Şifre:
Sayfa: [1] Yazdır
Gönderen Konu: Integra Type-R 1997  (Okunma Sayısı 659 defa)
RuSHeR_RaCeR
Honda Prelude
Offline Offline
Mesaj Sayısı: 628
« : Eylül 07, 2005, 02:53:13 ÖS »
: : : Motor
Toda Spec C Camshafts  Toda Camgears  Toda Valve Springs  Toda High Power Timing Belt  Alaniz Titanium Retainers  Supertech Valves  Wiseco/ImportBuilder Spec 12:1 compression Pistons  Koyo Aluminum Radiator  Koyo Radiator Cap  Probe Import Builder Spec Connecting Rods  Polished, Blueprinted, Balanced; Honda Integra Type R Crankshaft  By Steve Shelton @ Performance 1, Lexington, KY  Port and Polished Head By Joe Alaniz @ Alaniz Technology,  Honed and Bored Block to 82.5mm By Jeff @ ERL INC. New Albany, IN  ERL Fuel Rail By Jeff@ ERL INC. New Albany, IN  JDM APEXi Integra Type R 4-2-1 Header  AEM Cold Air Intake  AEM Fuel Pressure Regulator  RC Engineering 330cc Injectors  APR Head Studs  AEBS Main Bolts  J's Racing Straight Pipe Kit, Stainless Steel  ATS single plate clutch system (Metal)  STR Block Saver  Autronic Plug and Play Fuel Management System (tuned to 12,000 RPM!!!!!)  Espeiler JGT500 Cat-Back Exhaust System  Mugen Valve Cover.......Fake!  Mugen Reservoir Covers (SOX)  Mugen V1. Oil Cap  NGK Spark Plug Wires  NGK Spark Plugs  Valvoline Synpower 10w/30 Motor Oil  ALL new JDM/OEM Head gasket set Bottom End Gasket Set  ALL new JDM/OEM Honda Integra Type R Oil pump/Water Pump
: : : Dış Kısım
Honda Integra Front End Conversion  HID Kit 5200k  Spoon Weave Carbon Fiber Hood  JDM Integra Type R Front Lip  VIS Racing Spoon Style CF Lip  OEM Integra Type R Spoiler
: : : İç Kısım
Bride Ergo w/ Black Gradation(x2)  Bride Floor Brackets(x2)  Bride Sliders (x2)  Takata Harness (x2)  Defi D-Gauge Oil Pressure  Autometer Carbon Fiber Series Air/Fuel Guage  Sparco Flash 5 Steering Wheel  Signal Auto Steering Wheel  Skunk 2 Shift Knob  JDM Red Stitching Shift boot
: : : Lastikler/Frenler/Süspansiyon
Zeal Function B6 Coilovers  Mugen Front Strut Bar  WORK RZ-R 16x7.0 5x114.3 Forged Wheels  Rotora Four Piston Calipers, Rotora Rotors, Rotora SS Lines  ARP Extended Wheel Studs  Kryokugen Forged Lug Nuts
: : : Müzik Sistemi
Sony Xplode Stereo System  Pioneer Speakers All-Around
HONDA
« Yanıtla #1 : Eylül 07, 2005, 03:30:19 ÖS »
İşte gerçek hayalimdeki Type R
Kusursuz olmuş ne eksik ne fazla.
35YE720
« Yanıtla #2 : Eylül 07, 2005, 04:16:38 ÖS »
KatıLıyORUm GerCEkTen MUkEMMel
PeKi Bir SoruM War NedeN BıZ Bu AraClARa Sahıp OlAmıyoRUz TeK SebEbı SatıS poLıtAKıSI Mı?
EAC-V
Honda Integra
Offline Offline
Mesaj Sayısı: 174
« Yanıtla #3 : Eylül 07, 2005, 09:43:00 ÖS »
bununla sahıllerde gezdıgını dusunsene herkezın gozu sende. tr tek olacak. :shock:
ı-vtec
borayuksel
« Yanıtla #4 : Eylül 14, 2005, 04:04:19 ÖS »
çok sağlam  :shock:
justin
« Yanıtla #5 : Eylül 14, 2005, 04:39:41 ÖS »
ne yanlar bu..
can
« Yanıtla #6 : Eylül 14, 2005, 08:39:52 ÖS »
sağlammm Sırıtma
93si
Honda Prelude
Offline Offline
Mesaj Sayısı: 818
« Yanıtla #7 : Eylül 20, 2005, 01:30:40 ÖÖ »
Alıntı sahibi: "35YE720"
Benim düşüncem bu önceden belirtiğim dedim.
Bu olayın tek bir açıklaması var honda getiriyo yine(bi Vtec bi Sİ, s2000 type R)ama mesela bi toyota sağlam arabaları var ama getirmiyo veya bi nissan bunu tek bir sebebi var nası olsa tr dekiler her arabaya bayıla bayıla biniyo neden sağlam araba getirelimki düşüncesidir. Corolla satıp suprayı kendilerinde tutmak varken neden getirsinlerki?? Nasıl olsa Türkler ne bulsa alıyo budur yani
Arızalı-rahatsız
« Yanıtla #8 : Kasım 18, 2005, 01:03:14 ÖS »
harbiden cokkk fenaaaaaaaaaaaaaa :shock:
Administrator.
SENSEI
Offline Offline
Mesaj Sayısı: 6972
R 29110
« Yanıtla #9 : Aralık 14, 2005, 03:39:59 ÖS »
guzel bisii Cheesy
Sayfa: [1] Yazdır
« önceki sonraki »
Gitmek istediğiniz yer:
