Özellikleri
Engine Type V6
Engine Block/Cylinder Head Aluminum-Alloy
Displacement (cc) 3471
Horsepower @ rpm (SAE net)* 247 @ 5750*
Torque (lb.-ft. @ rpm)* 245 @ 4500*
Redline (rpm) 6300
Bore and Stroke (mm) 89 x 93
Compression Ratio 10.0:1
Valve Train 24-Valve SOHC VTEC®
Multi-Point Fuel Injection Standard
Drive-by-Wire Throttle System™ Standard
Variable Torque Management® 4-Wheel Drive System (VTM-4®) Standard
Locking Rear Differential Standard
Fresh-Air Intake Standard
CARB Emissions Rating ULEV-2
Direct Ignition System with Immobilizer Standard
Heavy-Duty Radiator with 160-Watt Fans (2) Standard
105,000-Mile Tune-Up Interval† Standard
Bu arada amerika sitesinde 3 adet paket opsiyonu var hepsinde aynı motor var,28 ile 32 bin dolar arası amerika fiyatı var arkadaşlar, Türkiye'de 2 katı olur heralde..
