Administrator
Turbo S2000
Offline
Mesaj Sayısı: 4868
Kaymakam
« : Aralık 29, 2006, 02:59:49 ÖÖ » |
Honda Civic VTi HB
Bodywork / Karoser Type: 4/5S HBK Number of doors: 0 Dimensions / Boyutlar Wheelbase: 2570 mm 101.18 in Track front: 1475 mm 58.07 in Track rear: 1465 mm 57.67 in Length: 4080 mm 160.62 in Width: 1695 mm 66.73 in Kerb weight: 1080 kg 2380.98 lb Fuel capacity: 45 l 11.88 US gal Engine / Motor Manufacturer: Honda Type: S-4 DOHC 16 valves total 4 valves per cylinder Main bearings: 5 Bore x stroke: 81.00mm × 77.40mm Bore / stroke ratio: 1.05 Displacement: 1595 cc 97.33 cu in Compression: 10.20:1 Fuel system: Ho PGM-Fi fuel inj. Aspiration: Normal Catalytic Converter: Y Max. output: 162.2 PS (160.0 bhp) (119.3 kW)@7600 rpm Max. torque: 150.0 Nm (111 lbft) (15.3 kgm)@7000 rpm Coolant: Water Specific output: 100.3 bhp/litre Specific torque: 94.04 Nm/litre Performance / Performans 0-60mph: 7.3 s Quarter mile: 15.80s Top speed: 212 km/h Power to weight: 148.15 bhp/ton Chassis / Sasi Engine / Motor location: Front Engine / Motor alignment: Transverse Suspension front: I.W.CS.ARB. Suspension rear: I.CS.W.ARB. Brakes: VeDi/Di-S-ABS Transmission: 5M Drive: FWD Top gear ratio: 0.88 Final drive ratio: 4.27
Honda Civic VTi Sedan
Bodywork / Karoser Type: 4/5S SAL Number of doors: 4 Dimensions / Boyutlar Wheelbase: 2620 mm 103.14 in Track front: 1475 mm 58.07 in Track rear: 1465 mm 57.67 in Length: 4405 mm 173.42 in Width: 1695 mm 66.73 in Kerb weight: 1118 kg 2464.76 lb Fuel capacity: 45 l 11.88 US gal Engine / Motor Manufacturer: Honda Type: S-4 DOHC 16 valves total 4 valves per cylinder Main bearings: 5 Bore x stroke: 81.00mm × 77.40mm Bore / stroke ratio: 1.05 Displacement: 1595 cc 97.33 cu in Compression: 10.20:1 Fuel system: Ho PGM-Fi fuel inj. Aspiration: Normal Catalytic Converter: Y Max. output: 162.2 PS (160.0 bhp) (119.3 kW)@7600 rpm Max. torque: 150.0 Nm (111 lbft) (15.3 kgm)@7000 rpm Coolant: Water Specific output: 100.3 bhp/litre Specific torque: 94.04 Nm/litre Performance / Performans 0-60mph: 7.7 s Top speed: 216 km/h Power to weight: 143.11 bhp/ton Chassis / Sasi Engine / Motor location: Front Engine / Motor alignment: Transverse Suspension front: I.W.CS.ARB. Suspension rear: I.W.CS.ARB. Brakes: VeDi/Di-S-ABS Transmission: 5M Drive: FWD Top gear ratio: 0.88 Final drive ratio: 4.27
« Son Düzenleme: Aralık 29, 2006, 03:02:38 ÖÖ Gönderen: VTEC »
  click on the image
SONE-R
« Yanıtla #2 : Aralık 29, 2006, 10:14:30 ÖÖ » |
beygir güçleri yanlış kardeşim nerden aldıysan..
160 PS veya 158 HP veya 118 KW olacak doğrusu budur....
G60
« Yanıtla #4 : Aralık 29, 2006, 05:19:01 ÖS » |
http://www.carfolio.com/  .
serkan
« Yanıtla #5 : Aralık 29, 2006, 05:22:01 ÖS » |
http://www.carfolio.com/  . Bad Gateway The proxy server received an invalid response from an upstream server.
G60
« Yanıtla #6 : Aralık 29, 2006, 05:27:17 ÖS » |
Adres doğru. Ancak sabahtan beri server'larında sorun var...
DeViL_CiViC_1
Honda Civic VTI
Offline
Mesaj Sayısı: 467
16 Z 5557
« Yanıtla #7 : Mart 11, 2007, 12:32:05 ÖS » |
mutunch
Honda Civic Type R
Online
Mesaj Sayısı: 1621
8253
« Yanıtla #8 : Mayıs 07, 2007, 07:07:15 ÖS » |
Arkadaşım beygir güçleri doğru olmuş. Neden mi ? Çünkü orada litre başına alınan beygir güçleri verilmiş  E bu durumda da doğru olmuş oluo litre başına 100 beygir.
« Son Düzenleme: Mayıs 07, 2007, 07:08:53 ÖS Gönderen: mutunch »
vtimania
« Yanıtla #9 : Mayıs 29, 2007, 04:24:18 ÖÖ » |
vti torku 156
hifi
Honda Jazz
Offline
Mesaj Sayısı: 1
« Yanıtla #10 : Temmuz 19, 2007, 02:38:07 ÖÖ » |
bencede litre başı verilen bilgiler dogru paylaşım için tşk
avci
Honda Jazz
Offline
Mesaj Sayısı: 10
yava$ git acelem var
« Yanıtla #11 : Aralık 23, 2007, 02:24:04 ÖÖ » |
b16a2 vti vtec motorlari 160 hp dir selamlar
selam ben 1992 den beri honda kulanicisiyim fransada yasiyorum aldigim arabalar 3 crx,2integra type r,1 accord type r,4 civic esi,ed7,ve $imdi 2 tane civic vti ferio 4 kapi 93 model jhm 170hp ve vti 1.8 mb6 98 model turkiyeye her yil honda ile gelirim en son honda accord type r 212hp malesef fotograflarim silindi herkese iyi bayramlar turkiyede honda meraklisi fransadan daha iyi $eyler yapiyorsunuz tebrik ederim selamlar
