Şifre:
Sayfa: [1] Yazdır
Gönderen Konu: Honda Civic VTi Teknik Bilgiler  (Okunma Sayısı 3871 defa)
Administrator
Turbo S2000
Offline Offline
Mesaj Sayısı: 4954
Kaymakam
« : Aralık 29, 2006, 02:59:49 ÖÖ »
Honda Civic VTi HB
Bodywork / Karoser
Type: 4/5S HBK
Number of doors: 0
Dimensions / Boyutlar
Wheelbase: 2570 mm 101.18 in
Track front: 1475 mm 58.07 in
Track rear: 1465 mm 57.67 in
Length: 4080 mm 160.62 in
Width: 1695 mm 66.73 in
Kerb weight: 1080 kg 2380.98 lb
Fuel capacity: 45 l 11.88 US gal
Engine / Motor
Manufacturer: Honda
Type: S-4
DOHC
16 valves total
4 valves per cylinder
Main bearings: 5
Bore x stroke: 81.00mm × 77.40mm
Bore / stroke ratio: 1.05
Displacement: 1595 cc 97.33 cu in
Compression: 10.20:1
Fuel system: Ho PGM-Fi fuel inj.
Aspiration: Normal
Catalytic Converter: Y
Max. output: 162.2 PS (160.0 bhp) (119.3 kW)@7600 rpm
Max. torque: 150.0 Nm (111 lbft) (15.3 kgm)@7000 rpm
Coolant: Water
Specific output: 100.3 bhp/litre
Specific torque: 94.04 Nm/litre
Performance / Performans
0-60mph: 7.3 s
Quarter mile: 15.80s
Top speed: 212 km/h
Power to weight: 148.15 bhp/ton
Chassis / Sasi
Engine / Motor location: Front
Engine / Motor alignment: Transverse
Suspension front: I.W.CS.ARB.
Suspension rear: I.CS.W.ARB.
Brakes: VeDi/Di-S-ABS
Transmission: 5M
Drive: FWD
Top gear ratio: 0.88
Final drive ratio: 4.27
Honda Civic VTi Sedan
Bodywork / Karoser
Type: 4/5S SAL
Number of doors: 4
Wheelbase: 2620 mm 103.14 in
Length: 4405 mm 173.42 in
Kerb weight: 1118 kg 2464.76 lb
Engine / Motor
Manufacturer: Honda
Type: S-4
DOHC
16 valves total
Main bearings: 5
Aspiration: Normal
Coolant: Water
0-60mph: 7.7 s
Top speed: 216 km/h
Power to weight: 143.11 bhp/ton
Chassis / Sasi
Suspension rear: I.W.CS.ARB.
Transmission: 5M
Drive: FWD
« Son Düzenleme: Aralık 29, 2006, 03:02:38 ÖÖ Gönderen: VTEC » Logged
timmaah
Honda Civic VTI
Offline Offline
Mesaj Sayısı: 326
« Yanıtla #1 : Aralık 29, 2006, 03:24:29 ÖÖ »
teşekkürler çok yardımı oldu geçen bi konu açılmış sedan mı HB mi die sanırım bu o konuya da aydınlatıcı olur
Bülent Ersoy dünya çapında bir sanatçı olacaktı fakat önünü kestiler... dişsiz dişsiz
SONE-R
Honda Civic Type R
Offline Offline
Mesaj Sayısı: 1590
« Yanıtla #2 : Aralık 29, 2006, 10:14:30 ÖÖ »
beygir güçleri yanlış kardeşim nerden aldıysan..
160 PS veya 158 HP veya 118 KW olacak doğrusu budur....
timmaah
Honda Civic VTI
Offline Offline
Mesaj Sayısı: 326
« Yanıtla #3 : Aralık 29, 2006, 12:53:10 ÖS »
Alıntı
vala bana beygirler doru gibi geldi ama HB nin kapı sayısı "0"mış onda bi yannışlık var sanursamm nerden binilio bu arabaya yahuuu  dişsiz
G60
Administrator
Honda Integra
Offline Offline
Mesaj Sayısı: 114
« Yanıtla #4 : Aralık 29, 2006, 05:19:01 ÖS »
http://www.carfolio.com/ Wink .
serkan
Honda Prelude
Offline Offline
Mesaj Sayısı: 776
« Yanıtla #5 : Aralık 29, 2006, 05:22:01 ÖS »
Bad Gateway
The proxy server received an invalid response from an upstream server.
ÖZER MOTOR
0212 521 42 19
www.ozermotor.net
G60
Administrator
Honda Integra
Offline Offline
Mesaj Sayısı: 114
« Yanıtla #6 : Aralık 29, 2006, 05:27:17 ÖS »
Adres doğru.
Ancak sabahtan beri server'larında sorun var...
DeViL_CiViC_1
Honda Civic VTI
Offline Offline
Mesaj Sayısı: 467
16 Z 5557
« Yanıtla #7 : Mart 11, 2007, 12:32:05 ÖS »
Alıntı
ahuahuahu camları açıp bnerler belki  Grin Grin Grin
mutunch
Honda Civic Type R
Offline Offline
Mesaj Sayısı: 1626
8253
« Yanıtla #8 : Mayıs 07, 2007, 07:07:15 ÖS »
Arkadaşım beygir güçleri doğru olmuş. Neden mi ? Çünkü orada litre başına alınan beygir güçleri verilmiş Smiley E bu durumda da doğru olmuş oluo litre başına 100 beygir.
« Son Düzenleme: Mayıs 07, 2007, 07:08:53 ÖS Gönderen: mutunch » Logged
Honda Hayat Onda
vtimania
Co-Admin
Honda Civic Type R
Offline Offline
Mesaj Sayısı: 1751
« Yanıtla #9 : Mayıs 29, 2007, 04:24:18 ÖÖ »
vti torku 156
hifi
Honda Jazz
Offline Offline
Mesaj Sayısı: 1
« Yanıtla #10 : Temmuz 19, 2007, 02:38:07 ÖÖ »
bencede litre başı verilen bilgiler dogru paylaşım için tşk
avci
Honda Jazz
Offline Offline
Mesaj Sayısı: 10
yava$ git acelem var
« Yanıtla #11 : Aralık 23, 2007, 02:24:04 ÖÖ »
b16a2 vti vtec motorlari 160 hp dir
selamlar
selam
ben 1992 den beri honda kulanicisiyim
fransada yasiyorum
aldigim arabalar 3 crx,2integra type r,1 accord type r,4 civic esi,ed7,ve $imdi 2 tane civic vti ferio 4 kapi 93 model jhm 170hp ve vti 1.8 mb6 98 model turkiyeye her yil  honda ile gelirim en son honda accord type r 212hp malesef fotograflarim silindi herkese iyi bayramlar
turkiyede honda meraklisi fransadan daha iyi $eyler yapiyorsunuz tebrik ederim selamlar
OzzWoLF
Honda City
Online Online
Mesaj Sayısı: 57
Kavusacaz bekle beni...
« Yanıtla #12 : Eylül 03, 2008, 04:41:44 ÖÖ »
paylasım icin saol
Sayfa: [1] Yazdır
« önceki sonraki »
Gitmek istediğiniz yer:
