Under Bonnet\ Performance:
B18c1 Motor
JG Intake Manifold
BBK 70mm Throttle Body
1200cc RC Injectors
AEBS Fuel Rail
ITR Head Port & Polish
Ferrea Valve Springs
Retainers
Lockators
JDM ITR Cams
AEBS Cam Gears
Custom Turbo Manifold
T70 Inovative Turbo Ball Bearing
46mm Tial Wastegate
Tial Blowoff Valve
3" Polished Intercooler Piping
3.5" Stainless Steel Down Pipe
AEBSOne Peice T-Sleve
84mm Ross Piston w/ Rings & Ristpin
Pauter Rods
Tilton Flywheel
Tilton Carbon Carbon Clutch
AEBS Type R Trans
Quaife LDS
AEBS Head Studs
AEBS Main Studs
Cometic Head Gasket
AEBS O-Ring Block
Type R Crank
Moroso Oil Pan
Moroso Pick Up
AEBS Electric Water Pump
AEBS Cam Seal
Manley 1/2mm over S/S Valves
Crane Cam Spark Plug Wires
HVC Coil II
MSD Digital 7 Ignition
Autrounic SMII
BBK Short Shifter
BBK Solid Trans Bushing for Short Shifter
Custom Motor Mount Inserts
Hyper Ground System, Spoon Oil Cap
Custom Valve Cover
Custom Gas Tank
SX Fuel Pump
SX Regulator
Earl's Steel Braided Lines
Greddy Oil Catch Can
XS GTR Intercooler
Tanabe Racing Exhaust
Exterior:
C-West Complete Body Kit
C-West Vented Hood
JDM CTR Headlights
JDM CTR Fender w/ OEM Side Marker
Custom Carbon Rear Hatch
Carbon Wing
J's Racing Canards
ARC Diffusers
Spoon Mirror
Custom Paint Job
JDM Parking Sticker
JDM Safety Check
and Bellof HIDs
Interior:
Bride Brix Seats Red
CTR Cluster
CTR A/C Console
CTR Red Carpet
CTR Door Panels
Custom Roll Cage
Parachute Mount
Wheelie Bar Mount
Window Net
Turbo Smart Boost Controller
Omori Gauges
CTR Road Flare
CTR Door Stickers in Door Jam
Spoon Steering Wheel & Hub
Sparco Steering Wheel Quick Release
Takata Harnesses
Spoon Shift Knob
CTR Shift Boot
Painted Inside Whole Car (no sound deadening)
Street:
Volk Racing CE-28 16x7.5
BF Goodrich Tires 205/40/16
Race:
Weld Magnum Rims in the front and back
Mickey Thompson 26/8/15 up front
M/H Skinny's in the rear
Tein RE Struts
CTR 5 Lug Conversion
ARP Extended Wheel Studs Front & Back
Skunk 2 Extended Lug Nuts
Spoon Rotors
Spoon Calipers
Cusco Break Booster Brace
Steel Braided Brake Lines
I.C.E. (in car equipments):
Kenwood TV/DVD
Eclipse Speakers & Amp etc.
